Radio Communications Logo
Question about Radio Communications
I have a delta m2 desk mic need wiring code for my dx2517
Posted by thomas siekkinen on
2 Related Answers
Anonymous
  • 170 Answers
SOURCE: magnum delta force
pin1 = mic audio,pin 2=receive, pin3= push to talk or transmit, pin5= shield.
cobra usually is white= mic audio, red= ptt, black= receive or speaker complete
Posted on Dec 28, 2008
Anonymous
  • 68 Answers
SOURCE: Telex rk-56, I need the switch inside the mic
I would suggest shipping the unit in with the mic and let me do it for you. www.dodgem250.com
Posted on Apr 12, 2010
How do I wire it to A 4 PIN Base Radio
Your question is a bit vague but here is a standard 4-pin wiring diagram.
Wiring for Adonis desk mic to midland 8001
http://www.adonis.ne.jp/e-desktop.html click the PDF link for the mic you have. 1 audio, 2 shield, 3 receive, 4 transmit
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.(same as the 4 pin exports)..
Use a ohm meter to find the correct wires on your mic switch.
then you know how to wire any mic to any transceiver.
This will work for the turner 2+2
Need to know how wiring goes on a cobra 4pin a d104 desk mic
match up the wiring diagram on the mic to the wiring on your radio.www.cbtricks.com
1helpful
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Magnum delta force
4helpful
6answers
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
2helpful
Wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
