Question about Vehicle Parts & Accessories
When I start my Aspen using the remote starter, it only runs for about 3 seconds and then it shuts off?
Posted by Mike and Bernie on
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Posted on Jan 16, 2009
Anonymous
  • 69 Answers
SOURCE: Reprogramming the factory remote starter on a 2008 Chevy Siverado
No, its a Auto-Anti-Theft Unit, your best bet would be to buy a $100 kit from auto zone. The Stick unit is built that way because if you start it and walk away, I can use a blank key to unlock the ignition and drive off.
Posted on Aug 18, 2009
Anonymous
Have this problem also. Took new vehicle (5009.2 miles) to dealer. They suggest that something in the control module tends to stick causing the battery to drain and that it is not an uncommon problem that they see. We had single digit temperatures here when the problem occured. It got up to 20 yesterday and everything works well again.
Posted on Jan 04, 2010
Anonymous
  • 88 Answers
SOURCE: Bulldog Remote Start Problem
if thats a key resisor bypass i never heard of that, i would check with with bulldog to see if may be a set upproblem
Posted on Jan 24, 2010
Anonymous
  • 306 Answers
SOURCE: viper remote starter starts car for about 3
it sounds like it lost its tachometer signal. what kind of car?
Posted on Feb 07, 2010
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
2008 chrysler aspen shut down completely in drive and won't start. Starter engages but won't start starter wire also gets very hot.
Engine froze up or not able to turn with the starter that is drawing alot of current to try to turn the motor
Dec 27, 2015 | Chrysler Cars & Trucks
My 07 Chrysler aspen will not start but my battery is good, all accessories work, my electronic throttle control light stays on, and there is also a small red light flickering
actually your aspen would start then die out after about 3 seconds. if you have tried this repeatedly, Now it does not start at all (your ECU is now locked up since it thinks you were trying to steal the vehicle). The little red light is your antitheft system. Your remote head key has failed. You can find a locksmith that does these at www.findalocksmith.com or you can have it towed to the dealership for a computer reset and another key.
Aug 30, 2014 | 2007 Chrysler Aspen Limited
Mars 22 car starter. car starts for a second then turns off
Your truck most likely has a chip in the key. You will need to contact the maker of the remote start kit you have and see if they make a kit to bypass the chip key.
Nov 20, 2013 | Omega MARS-22 Remote Vehicle Starter with...
2009 dodge grand caravan 3.8l. remote starts vehicle then shuts down after 5 seconds whats the solution
sounds like your factory alarm is not working with the remote starter. it happens a lot with the new cars. check the BCM that runs the factory alarm.
Dec 15, 2012 | 2008 Dodge Grand Caravan
My 2007 Ford Edge W/ Mars 22 remote start will start for 2 seconds when you hit the start button then shut off then start again then 2 seconds later shut off and will repeat this 2 more times, then will...
put your key in the ignition leave it in the off position, push your remote start button, if it starts then it has something to do with the transponder bypass "key in the box" or the loop around the ignition switch under the plastic cover
Feb 23, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Car starts but shuts off after 15 seconds
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Feb 10, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Remote starter on a 2004 Accord with V6 engine
remote starter is designed to shut down the vehicle if there is no key to drive with. This is a security feature so that unauthorzed drivers cannot steal it. to answer second question the purpose of remote starters is to allow you to heat up the vehicle so it is an ice cube when you are ready to drive. Not sure what remote I cannot answer the horn question. Need more on what remote starter you have model number and make
Apr 20, 2009 | 2004 Honda Accord
Viper remote starter-
Jan 15, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
256 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
