Question about Home
I have a king pellet stove 5500m. It was working fine. Err-2 and shut down. I checked exaust. Fuel supply. Door seals. Draft fan now won't start when I turn the stove on.
Posted by Shannon Cleveland on
2 Related Answers
Anonymous
SOURCE: 5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Posted on Feb 07, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: I have a king 5500m pellet stove and here recently after 15-30 minutes of running the exhust fan starts kicking off and on, it sounds like it in limbo and doesn't know what to do.
Replace the fan motor is what you need to do.
Posted on Feb 09, 2017
Just replaced motor on pellet stove
What was the original problem and what motor was replaced? Draft? Auger? Or blower? Did you disconnect power while working on it?
The first thing to check is that it has power and that the thermostat is turned on/up.
Without knowing the brand/model# it is tough to give assistance but what I normally find on pellet stoves is a faulty control board. It may also have a fuse that is popped.
Jan 28, 2018 | Cars & Trucks
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Jan 16, 2011 | Napoleon Auburn Pellet Stove Heater
How to clear error code on ussc stove pellet 5500m
im working on a pellet stove model 6039 hf when stove is on the draft fans light stays on i cleaned very good what next
Jan 12, 2011 | Heating & Cooling
We have a pellet stove -seems to be working ok except that we have a smell of smoke like that of having a fireplace. We think everything is sealed correctly. Any suggestions?
From what I have read on these things, never had one, but they have 2 fans, maybe one, plus an auger and thermostat. The one fan would **** fresh air in from the room to fuel the fire, while the other fan would blow the heat back out from a sealed area. The auger spins constantly, slow, dropping pellets on the fire determined by the thermostat. If this is right and relates to your stove, I can see where the smell of smoke would come from. The second fan is pulling in smoke from the fire. Check the gaskets in that area. I was wondering if it wasn't just the new stove smell you were getting?
Feb 23, 2010 | Napoleon Auburn Pellet Stove Heater
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Home Logo
215 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
