Radio Communications Logo
Question about Radio Communications
How to reset a g-boom g650a
Posted by deanne hauschultz on
1helpful
I have 2 boom boxes where cd's spin but no sound.
Its probably a lens failure, its quite common, try cleaning the lens,
if all else fails, try turning the unit upside down and load the disc, sometime this for some reason - resets the lens if slighty out but its not fact, just something i heard
2answers
Furby boom
Cannot get furby boom to connect to iPad or iPhone . We have 2 furby sand neither will connect. Only advice on instruction is move them closer but this doesn't help, any one else had this issue?
1helpful
How to reset the timer?
how to log on timer my Pioneer 7500W PMPO Ultra Bass by X Boom
6helpful
2answers
H710 won't reset after holdg all buttons. can't get pairing mode
If you can't reset your device- try this, which I just fiddled with and got mine to work (I had same problem). On headset, close boom, hold center button (and it turns pink). then, while keeping center button depressed, open boom- light remains pink. Then look on phone, and hit Add new device-- and bingo, it should be recognized now!! You'll be asked if u want to pair w/ Motorola-- and led through the process--follow those steps. The passcode, as mentioned by others on these posts, is 0000 (four zeros).
I had tried similar earlier, but the trick was to keep the button depressed, and then open the boom. I can't quite remember if I kept button depresed until I also pressed Add new device on phone or just until after opening the boom and the light stayed on ... Sorry I can't be exact; I was too excited. Hope this helps you get yours working!
5helpful
Motorola H710 will not reset even when holding down all 3 buttons for longer than 10 secs. It continues to blink blue in receiving mode. Is there a total reset for this headset?
No sound on a Sharp 37" Aquos TV
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad and they will send a repair tech to replace the pad for free, even if you are out of warranty.
1helpful
Squeezebox boom stuck in demo mode
Hi !
reset it !
Unplug the power cord , push and maintain the " + " button and replug the power cord, release " + " when you see " Factory reset ", then Fixed !
Have a gret day !
J -
29helpful
How do you reset it?
Turn the headset off (flip the boom in) then hold down the talk botton. The indicator should turn solid purple. Keep holding the the talk button and turn the headset on (flip the boom outward) and then it should stay soild purple and ready to pair with your phone.
Good luck.
10helpful
9answers
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
1helpful
2answers
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
