Question about Home
I have a Stokkur 3 handle shower and tub faucet. Where can I find handle parts?
Posted by Annie Wong on
5 Related Answers
manhandy
paul sandouk
  • 146 Answers
SOURCE: Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Posted on Jun 26, 2009
Bill Johnson
  • 306 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
David Burk
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
Mike
  • 4369 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
Al Miller
  • 36 Answers
SOURCE: I have a Moen single handle tub/shower faucet. I
Your problem is in the water restrictor located inside the shower head. All plumbing manufacturers install these small plastic internal blockers to reduce water down to 2.5 gals per minute. In your case, this restrictor is most likely filled with sediment which is restricting it even further. Remove the shower head from the curved shower pipe. Look inside where the water goes through it. You should be able to see the restrictor. Maybe you can flush out the sediment. Otherwise, remove it and I'm sure you'll get more pressure then originally installed. Because most restrictors are sort of plastic screens or cones, I usually put a wood screw through the center of this product and then once a few threads bite in, I use a plyers on the head or the screw and pull outward while holding the shower head in a stable position. If you are able to get it out, technically your "out of code" because now your going to get all the water it can really supply.Most people are delighted to have it gone.
Nimsgame
Posted on Feb 15, 2011
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    How do I put seats and springs in a glacier bay Aragon three handle knobs
    How to Repair a Glacier Bay 3 Handle Tub and Shower ...
    www.faucetinstructions.com > Glacier Bay Faucet Instructions
    My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
    Nov 07, 2015 | Plumbing
    Pegasus tub and shower thermostatic faucet handle stripped
    Sep 24, 2012 | Pegasus Technologies Plumbing
    We have a new shower. Water comes out of shower head and tub faucet together. What do I need to do?
    its because that model usually when u pull for the shower is not properly connected. You will have to remove handle and coverplate, then shine flashlight down to see what is happening when pulling rod on tub spout for shower. Usually its broken or bent and just needs new one installed. It cost me 2 buck for new shower rod. Directions u can get free from Moen with free lifetime parts.
    Oct 06, 2010 | Moen & One Handle Tub & Shower Faucet
    How do you tighten or remove handle on a danze shower faucet
    Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
    Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
    Jul 02, 2010 | Danze & Single Handle Tub And Shower...
    & One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
    these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
    May 16, 2010 | Moen & One Handle Tub & Shower Faucet
    I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
    The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
    May 13, 2010 | Moen & One Handle Tub & Shower Faucet
    Home Logo
    450 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
