Question about Dual Audio Players & Recorders
How do i pair my novision tableta with a dual media player radio
Posted by Dominique Williamson on
Tring to install blutooth to my xdma7715 dual cd player
The Dual XDMA7715 unit does require a separate module called the Dual BTM60, as technically the XDMA7715 is a "Bluetooth Ready" cd player.
Assuming you have bought this module, the next thing you need to do is 'Pair it" with your mobile device, which I will assume is your cell phone. This keeps it from connecting with other people's cell phones as they drive by your car.
Before you begin, you need to prepare your phone for paring. Check your cell phone's users manual if these instructions don't apply, but generally this means you find the Bluetooth menu on your phone, turn bluetooth on, and make the phone 'visible' which means your stereo will be able to see it in order to pair up with it. Usually, turning visibility on only lasts for about 30 seconds, so you may have to try this more than once to get the timing done right. Once paired, you won't need to turn the phones visibility on again until the next time you pair a device.
Now that your cell phone is ready to pair with the stereo,
1) Press the Phone symbol on the cd player or the BTM60, pr press MODE until 'DUAL_BTM60" is displayed.
2) Press and hold the phone symbol on the cd player or the BTM60 for 5 seconds, until "PAIRING" is displayed. The Bluetooth icon will flash every second. The Cd player will broadcast its "availability" for 60 seconds.
3) Complete the pairing from the Bluetooth menu of your cellphone by selecting "Search for new devices". When they find each other, the Bluetooth icon will illuminate solid, and your phone will say it has found device "DUAL_BTM60", and ask you for a password to pair it.
The BTM60 device name is "DUAL_BTM60".
The password you enter into your phone to accept the pairing is "1234"
Now that the devices are paired, you should be able to make calls handsfree, and play music stored on your phone.
I hope that helps.
Nov 24, 2009 | Dual Car Audio & Video
WHAT IS THE PROBLEM WHEN A NO SIGNAL SIGN COMES UP ON A CAR RADIO DVD PLAYER
Well first off , what are you powering the dual from...is it "switched" power and fused? Secondly, what media are you using? A store-bought DVD or your own from a PC?
answer these and I'll help out
Jun 14, 2009 | Dual XDVD8181 Car Video Player
Wrong disc error coby poeratbel dvd player TF-DVD7307
Dale una limpieza al laser si no funciona checa la tira flexible que conecta el laser con la tableta tiende a quebrarse por el uso excesivo.
Mar 16, 2008 | Televison & Video
RCA LYRA MC5102A
Some Dual clock radios will not work with Philips products. If you are for sure that it is compatible with Philips contact them using the following number...
USA-1-888-755-5477
Nov 29, 2007 | Philips HDD1630 MP3 Player
37 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
