Question about Hitachi Televison & Video
I have a Hitachi LED TV model # LE50A6RA, no picture
When I turn on the TV I have no picture, just sound. I turn the TV off and back on and the picture works. Today it would not come on and turning the TV off and back on did not work. Finally after many tries it came on. Backlight is working, I can see the lights thru the back. Now I have a picture but it is very dark. I have tried to turn the backlight up, have it set to max 100%, still too dark.
Posted by Eric J Berger on
5 Related Answers
micromaster
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
Anonymous
SOURCE: Samsung LTN1765 has blinking green power indicator, but no picture or sound
Try replacing C51, a 10 microfarad 16v. surface mount electrolytic. It's near IC23 on the upper center of the board.
This part had high ESR on a couple of sets I serviced which
kept the power supply from starting.
Posted on May 10, 2008
Anonymous
SOURCE: Hitachi plasma tv
you trow away you're tv and you buy a new one ok
Posted on May 14, 2008
Anonymous
SOURCE: light won't turn off phone flashing
I hope this will help. I had the same problem with the message alert light not turning off. I have phone service through the internet. I would clear messages from my base unit and alert would continue to flash. I went into my internet message center and found a few old messages there. Why they got there is beyond me, but after clearing them my alert light went out and stayed off. I disabled messages to internet inbox and now it flashes only when I get messages to my base unit until I listen or clear them. Easy fix to annoyance I've had for some time.
Posted on Nov 26, 2008
Fujitsu
Martin Velazquez
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
Hitachi lcd tv model le55u516 no picture no sound
Have you got an led light on TV? if you do try another socket and control switches on the TV.
If no led light then try another wall socket and fuse in plug.
Hitachi LE55S606 Owner Manual
Jun 14, 2018 | Hitachi Televison & Video
I turned my hitachi tv on and i have no sound or picture what can i do ?
Are you getting the red led light? If not, please check the power outlet for any loose contacts. Try the TV on some other power outlet. If the TV does not work still, cool it off for 48 hours, after removing the plug and retry.
Aug 16, 2012 | Hitachi Televison & Video
Hitachi 42pd6800 black screen when turned on, got sound no picture
Is this a plasma or an LCD TV? If it's an LCD TV then I would check the backlight inverters. If it's a Plasma TV then The Sustain boards there are two sustain board.
You can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Hitachi Televison & Video
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 50V500, no picture ,sounds for about 15 sec.then goes off
I would try to re-seat the lamp. Pull the lamp out, check it to see if it may have gone bad again, then put it back in to make sure the contacts are connected. Before applying power, unplug the TV for 5 minute, and then plug in/turn it on.
Most lamps, if bad from the factory, will go out within 3 months of use. It does happen, and happens more often than you would think.
Try this, and see what happens. Good luck.
Jan 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
No sound, no picture, blinking LED.
You must use the original stk 392-110 and stk 392-150 and do not mix them up. There is one of each.
All the suggestions about substituting other ICs for 110's are Bullplop, except for Hitachi manufacturers upgrade with changed resistor values included.
Oct 25, 2008 | Hitachi 46F500 46" Rear Projection...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 57G500a no picture but has sound
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture
Replace IC (TDA8385J)
Sound but no picture
Check the LOT cable for short circuit
Nov 24, 2007 | Hitachi 57G500 57" TV
Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
Aug 08, 2007 | Hitachi C25-RF35S 25" TV
Televison & Video Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
