Question about American Standard Home
American Standard 4061 toilet. Can periodically hear the toilet refilling when not in use. No visible issues. Replaced the flapper. Leak remains. No visible cracks on drain tube or tank.
Posted by Garry Granger on
Steve Pack
  • American Sta... Master
  • 4,400 Answers
These are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
Posted on Nov 12, 2018
1 Related Answer
Anonymous
  • 35 Answers
SOURCE: I have a American Standard Carlyle, with a leak
Yes it must be cracked between the tank and bowl . Take a #2 pencil and and rub it back and forth inside the tank that should show the crack. Good Luck
Posted on Dec 02, 2009
Fix an american standard slow close toilet seat
Check the chain the goes between the handle and the flapper.
It should not be taught. If it is it will not permit the flapper to seat
properly and water will leak out. Adjust the chain length so the flapper is seated and there is just a little slack in the chain.
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Why does my toilet suddenly fill the tank?
Usually seeping is from under the flapper. Replace flapper with one designed for that model. Avoid generic flappers.
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
1helpful
Problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
2helpful
Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
American Standard Hamilton Toilet Leaking
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
Sep 26, 2009 • Home
2helpful
Flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
1helpful
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Home Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
