Televison & Video Logo
Question about Alba Televison & Video
How can increase the volume on my Alba TV? I have done everything recommended with the remote control and it is still low.
5 Related Answers
Anonymous
  • 65 Answers
SOURCE: Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Posted on Dec 09, 2006
Anonymous
SOURCE: TV volume increases by itself and doesn't decrease or respond to the remote control
Apparently this seems to be a known issue for this model. I called Phillips and they did not even bother asking me to try things like switch off and on again etc...They just said they are going to send someone to pick it up and fix it. I would suggest to everyone to do the same since it has to be free of charge because the problem appears in pretty much every tv set of this model.
Posted on Apr 28, 2008
ohms
monk3ybidzness
  • 1879 Answers
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Posted on Sep 30, 2008
Anonymous
  • 44 Answers
SOURCE: I am unable to find the volume control
its an invisible touch button found on lower right hand corner of screen. or on thin right side.
Posted on Feb 26, 2009
Anonymous
  • 92 Answers
SOURCE: How to increase speaker volume on Dell Vostro
it might having a problem with your speakers,change it...or change audio cable pin or check it by moving it or by inserting it correctly in audio panel
Posted on Dec 15, 2009
Have a Techwood 55inch smart TV. It's just done a update but now the only sound we get is through the sound bar. Press volume up on tv remote, numbers go up but no increase in sound. Any ideas?
My TV has a setting to shut off the internal speakers. Like yours, if it is set to off, then I can turn up the volume with the TV remote and the volume does not increase, even though the volume number goes up. Maybe your TV has a similar setting.
1helpful
Volume intermittently increases all the way to 100 and cannot be controlled by the remote
This happens with some models. You can open the TV from the back and disconnect the connector for the side control board. You will only have control via the remote but your volume issue should be resolved.
Model #57733 - Volume will randomly increase without notice. Remote control no longer communicating. Have tried the reset button.
the volume control is increasing randomly on it's own because the volume button on the TV is partially stuck in, that is why its coming up occasionally. This same thing may also happen to the remote control of the TV.
Use your find to rub the buttons on the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Regards.
Remote code for commtel control freak remote.
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Alba TVs in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the One For All URC-3021 Code Search, feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
2helpful
Having connected up my PVR915OT I am unable to increase the volume on the TV to a reasonable level of volume using the Humax handset- can you offer a solution please?
As far as I recall, the volume control on the PVR remote only controls the volume from the PVR. So, select the volume fully up (using the PVR remote) then increase the volume on the TV (using the TV remote) until it's as loud as you can stand. You can then adjust (decrease) the the volume to suit using the PVR remote.
The volume does not change when connected to my tv. The volume does change when i play dvd's. I have had it working before but since I have moved it does not. please help.
TV remote varies the TV amplifier drive - you are probably plugged into the "line" output of the TV (which is before the TV amplifier). Line out is a fixed level (your DVD preamplifier is controlled by the DVD remote).
Anyway, with the TV on - go to the home theater box and increase the volume there. Once you get that set, you should be able to use the Home theater remote to always control the volume for everything displayed on your TV (except channel changes)
1helpful
Volume increases to 30 can't turn down
I don't have a solution but if you take off the speaker grille on the front of the set and see two ribbonish cables, unplug the smaller one. The volume will not increase anymore but you cannot use the controls on the front of the tv and the power light will not show green anymore. You can however use the remote to do everything on the set that you would normally do. Hope this helps until I find a real solution.
6helpful
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
