Question about AudioBahn Car Audio & Video
How to setup Audiobahn 2601 Amplifier to 2 12in Hifonics subwoofers
5 Suggested Answers
Anonymous
  • 109 Answers
SOURCE: i want to install a
Get an aftermarket to factory wiring adapter. You can find out exactly what part you need by following this link:
http://www.crutchfield.com/cgi-bin/autoinfo/autoinfo.asp?lp=%2fapp%2fCar%2fMyCar.aspx
Posted on Jul 17, 2008
Anonymous
  • 22 Answers
SOURCE: lights dimming
It doesn't hurt to have a separate battery for your system but not necessary. You're pulling enough power to do it if you want to save the beating your alternator takes evan with a power cap
Posted on Dec 04, 2008
agent001
  • 16 Answers
SOURCE: Subwoofer trouble
does your deck have a sub control on it sub on or sub off are your rca jacks plug in to the right one are your rca cables in good shape speaker wires hooked up properlly amp is set on low pass filter
Posted on Jul 07, 2009
Anonymous
  • 19 Answers
SOURCE: My audiobahn amplifier isnt working, the status
it maybe fixable. the problem is that when you find what is burnt or messed up, you replace it. after that you need to find out why it burnt or messed up. i wouldnt recomend trying to fix it your self unless you wanna chance it. but if you take it to a technician that can fix it the will be able to tell you if it can be repaired. also check your power and ground wires. make sure youre getting 12 volts to the amp. check your subs and make sure they are good. a bad sub will put a amp into protect. good luck.
Posted on Dec 27, 2009
hoyzee1
  • 150 Answers
SOURCE: how should i arrange the wiring on my xm-zr1852
it depends on the impedance of the subs-if your subs are dual 4 ohm coils then you can parallel the coils which will give you 2 ohms per sub- you could get max performance from your amp by just wiring the 2 ohm speaker load to each channel of the amp which will hit them with about 200 watts rms each. another way to do it is to wire the coils in series which will make each sub an 8 ohm load and then parallel them together and that will show a 4 ohm load -which you can use to run the amp safely in bridged mode. This will give you exactly the same amount of power to your subs as in 2 ohm stereo will. so with your amp being 2 ohm stable in stereo or 4 ohm stable in bridged mode- those are the numbers you want to hit for maximum"safe" operation
Posted on Jan 16, 2010
Could i wire my audiobahn Eternal subwoofers to my surround sound system?
is your subwoofer self amplified? if it has, you can connect it through audio sub output and in put to your self amplified subwoofer.. if it is not self amplified, you can still connect it but be sure it ca drive your subwoofer, it depends on RMS or watts of the original sub of the srround..or you can have a seperate amplifier only for your subwoofer. "Audio out - Audio in"
Aug 10, 2012 | AudioBahn AWES12P Car Subwoofer
What would be the best size amp to purchase for two audiobahn aw1200 subwoofers and two pioneer 4-way 6"x9"?
First, I would purchase the amp based on the subwoofers alone. Allow unit power to run the 6x9's unless you are planning a intricate setup. Things to think about when buying your amplifier. Always get an amp that offers an RMS output of 25-30% greater than the combined RMS output of your subs. Also, the stability of the amp to handle ohms loads (1, 2, or 4 ohm stable). If you have two dual 4 ohm subs you can get a 2 channel 2 ohms stable amp, or a monoblock 1 ohm stable amp. This will get you the most power and sound for your buck. There are so many amplifiers out there at different price levels, it's really up to you. Hope this helps.
Sep 03, 2011 | AudioBahn AW1200 Car Subwoofer
I recently purchaced the subwoofer and the guy lost the manual for wiring the sub in the box can you explain how to do that?
Here is an excellent reference for wiring any Subwoofer to any Amplifier:
http://www.crutchfield.com/S-jXlGCwReN8E/learn/learningcenter/car/subwoofers_wiring.html
Choose your Amp configuration, number of subs, then the Voice-Coil setup and Ohm Rating.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 28, 2011 | Hifonics AS12SQ Car Speaker
How do i wire my 15 inch audiobahn AW1571T ?
  1. You can find a wiring diagram for your subwoofer and amplifier at the following website: http://www.crutchfield.com/S-jXlGCwReN8E/learn/learningcenter/car/subwoofers_wiring.html
Jan 19, 2011 | AudioBahn Car Audio & Video
Audiobahn Alum 12q (12inch)
yea, check out audiobahn a2300hcx
Dec 26, 2009 | AudioBahn ALUM8P Car Subwoofer
How bridge the 15" 800 rms speakers audiobahn
parallel wiring (if your amplifier is 1 ohm mono stable)
All positives together and all negatives together.
If your amplifier is not 1 ohm mono stable you will need a series/parallel which is a little more difficult.
Here is a wiring link.....
http://www.the12volt.com/caraudio/woofer_configurations.asp
Dec 16, 2008 | AudioBahn AWES15P 15" Subwoofer Car...
Lights dimming
Dec 01, 2008 | AudioBahn AW1206T Car Subwoofer
Audiobahn powered subwoofer
yep, they dont make audiobahn any more i think they still make other subs to one of them is DUB subs, ebay is the best place for me to find audiobahn, and for parts...
Jul 24, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
73 people viewed this question
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Professor_V
Professor_V
Alphanso Tee
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
