Question about Home
Clock stopped and does not react to a new battery, help please
Posted by Colin tgompson on
1 Related Answer
sylviaivie
  • 1564 Answers
SOURCE: Electronic clock not working. Have tried new batteries &fingers just spin around then stop at either 4 or 12. HELP!!!!
Your clock is not a sewing machine.
Posted on Sep 13, 2012
Nikon D90. blinking "clock" sign in the top LCD panel. Any advise?
Sounds like you may have a circuit failure. Possibly the phase switch but that is not the usual symptom. In any case this should be sent to Nikon as they stopped selling parts a year ago, and also you need their proprietary software to initialize a new board if it is replaced.
Jun 13, 2014 | Nikon DSLR D90 Digital Camera
Changing the battery on a LIFEMAX atomic talking watch
verything is okay with the wiringThe wiring might have been messed up.If everything is fine with the wires,then,contact a clock repair shop.
Oct 20, 2012 | Lifemax Heart Rate Watch
We have an Atomic Lacrosse WT-3143A clock; the battery ran out and a new one was put in. The hands rotated and stopped at 8 o'clock. We pushed ET buttons on the back and nothing happened, pushed the...
Directions:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
[email protected] (warranty work)
[email protected] (information on other products)
web: www.lacrossetechnology.com
Sep 02, 2010 | La Crosse Radio Controlled Atomic Clock
Stopped working
check the accessories fuse
Feb 16, 2009 | 1995 Ford Contour
D50 Battery & clock icons flashing
well i had only the clock icon flashing and after setting the date and clicking an enter on it disappeared my battery icon's all good...about the battery thing i would recall what happened before the icon started to flash might be helpful maybe the inner spring got a damage or the upper sheet metal or membrane as you please has something... cause it happened to me couple of years ago but it got solved and i cannot remember how sorry...definitely there is an easy solution cause i had not had to take it anywhere...
Nov 23, 2008 | Nikon D50 Digital Camera
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
52 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
