Question about Home
Audubon Society Audubon Singing Bird Clock diagram of inside wire connections. Got one at a garage sale only to find out all the wires are tore off from the solder. I don't know where they go.
Posted by Pat Hansen on
5 Related Answers
Anonymous
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: Bought a 14' Weedeater at a garage sale - like new.
Please go here to download a .pdf manual for your #900-74528 trimmer.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 29, 2009
Anonymous
SOURCE: Wires came loose of control unit from circuit
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Posted on Apr 22, 2010
Joe Hogan
  • 10865 Answers
SOURCE: I have a liftmaster formula 1 garage opener. My
Hello. The line from each sensor runs to the control panel on the motor. If you climb up and take a look at the rear of the motor you will see the other end of each wire. J.
Posted on May 27, 2010
johnjohn2
Johnny Brown
  • 5763 Answers
SOURCE: need a diagram for wiring trying to trace wiring
Posted on Oct 04, 2010
There's only one battery visible and it doesn't sing. Where are the batteries for the sound?
It is located on the back side.
2 total batteries for this type of clock, one for the time piece the other for the audio portion.
I have a cool clock like yours, but mine is Corvette Engine sounds. Very Cool.
There is a small door with a screw.
Mar 15, 2015 | Audubon Society Audubon Singing Bird Clock
Birds will sing only when you push the red button
The contact in the time movement isn't closing on the hour.
Nov 04, 2013 | Audubon Society Audubon Singing Bird Clock
Our bird clock has started running fast, gaining about 17 minutes each day. Any idea how to fix this?
No fix, other than replacing the time movement, which is a switch movement that can be purchased at several different clock part supply stores, catalogs, or websites.
Jul 14, 2013 | Audubon Society Audubon Singing Bird Clock
Why does my owl hoot at 10 instead of 12?
SETTING THE TIME: ( Remove all batteries before setting)
1. Turn the hand set knob in the rear of the battery compartment clockwise or counter clockwise to read 10 minutes before 12:00 o'clock (11:50)
2. Insert three " AA" batteries into the battery compartment
3. Now turn the handset knob clockwise to adjust the desired time.
Note: Each time the set test button"red" is pressed, this sets the birds melodies to the next hours bird. If pressed, you must follow the instructions above to reset properly or you will not hear the correct melody with the correct bird.
I found this answer on another site: http://answers.yahoo.com/question/index?qid=20080115175404AAdL2Lw
Hope it helps!
Jan 19, 2013 | Audubon Society Audubon Singing Bird Clock
Home Logo
125 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
