Question about Connex Radio Communications
Where can I get a user's manual for the connex cx-3400hp
Posted by Todd Sorensen on
2 Related Answers
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: i just purchased a connex 3400hp and my cb freinds
The Cobra 29 has always been a good talking radio and is preferred by truck driver mainly for that reason! The Connex is a great radio in it's own right but sometimes needs a little help. I would suggest a power mic and there are many to choose from but Astatic is a clear winner! My two cents for a suggestion!
Posted on Mar 07, 2010
Bigfoot350
  • 6 Answers
SOURCE: I have a connex cx-3400HP d and a r not working until the unit get's hot
Take it to a good cb shop radioactiveradios do really good work on connex radios
Posted on Jun 06, 2012
Connex 3400 hp makes static noise when I hit bumps in road.
don't hit any more bumps. The problem could be in several areas. I'm going to say that you may have a loose capacitor inside If I had the radio here I could fix it but because the problem may be so spread it could be a lot of things Are you a truck driver? If you are take it to a CB shop at one of the many truck stops and see if they can fix it for you .
Jan 22, 2016 | Connex CX-3400hp AM/FM 10 Meter Amateur...
I have a Connex 3400 Hp and it stopped receiving all of a sudden while driving down the road and the needle on my meter is dead on 0. I've doubled check to make sure all my knobs and switches we're in the...
check for a fuse bulb for the RX section i would have a radio engineer look at it as you smell stuff
its also not a good idea to drive around with known faulty electronics in your car its a bad problem just waiting too blow up in your face... so.. dont leave electrical issue in cars your family depends on
Feb 16, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Converting 10 meter to 11 meter on Connex CX-3400HP CB RADIO
Turn the mode switch to the setting you want and leave it there .
Jan 10, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
May 27, 2012 | Connex CX-4300HP CB Radio
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
I just purchased a connex 3400hp and my cb freinds tell me that my other radio sounds better than the cx 3400hp,my other radio is a cobra 29 ltd classic.my 29 has more audio and modulation and both radios...
Mar 07, 2010 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
140 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
