I would think the coolant level safety feature triggers the fault and /or parameters set up or programming.
There might be two reasons for the failure of generator auto start.
1. It is the ATS automatic conversion control device that does not issue the start generator command after the mains power failure or phase loss operation, or the self-starting relay failure, which causes the generator to not start itself. This situation is relatively rare.
2. It is the generator start battery failure, and this kind of situation is relatively more.
SOURCE: 1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
SOURCE: I have a Kohler 12RES, 12.5kw genset. Less than a
Replace mag pick up. Cranking voltage on the MPU should be at least 2 volts AC. Normally MPU goes out.
SOURCE: I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
please provide the generator controller model i mean which controller is installed.
