Question about DISH Network Televison & Video
How can I get my Dish Network remote to work again on my Seiki LC32G82 tv? It was working fine until Hurricane Michael. Now the volume and mute buttons no longer work. I've tried reprogramming using the TV Pairing Wizard as well as manually entering pairing codes several times. I even tried a brand new Dish remote and can't get the volume and mute to work. Any ideas?
Posted by Jen L on
Will
    Habit-Forming:
  • 91 Answers
See the guide below for step by step instructions.
Posted on Mar 27, 2020
4 Related Answers
Anonymous
  • 336 Answers
SOURCE: dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
Posted on Sep 16, 2009
Anonymous
SOURCE: controlling my Sylvania LC320SS8 with my Dish Network remote
Codes didn't work. Power scan did though. I used to work for Dish Network in AZ. First training class when it opened in AZ. I call it now DOUCHE NETWORK. Corporate America SUX, and DOUCHE NETWORK follow that to the fullest extent of the LAW.
Posted on Jun 12, 2010
BeckiB_DISH
Becki Barned
  • 286 Answers
SOURCE: My friend has a
Hello, my name is Becki Barned, and I am with Dish Network customer service. To program the remote to a Vizio tv, there are a couple approaches that you may take. First is, follow this link: http://www.dishnetwork.com/SupportSection/power-scan-instructions which walks you through it. Or do these steps: 1. Hold down the TV mode button until all mode buttons at the top of the remote light up, then release. 2. Punch in the code 505. 3. Press the pound (#) button on the keypad. Use either of these, and that remote will work great! Just make sure after you get the volume working, that you press the SAT button on the remote! If you have any other questions, blog back, or you can find us on Twitter!!!!
Posted on Dec 24, 2010
NickF DISH
NickF DISH
  • 36 Answers
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Posted on Jan 03, 2011
I have an ol RCA tv, new dish remote everything works but the mute button...i can raise and lower volume, turn off and on but not mute
Hi there Stacey, my name is Kimberly and I form part of the Social Media Department with DISH. We do not promise that our remote will control all the functions of you TV. The codes used to program your DISH remote to the TV may be limited to some functions. You can try addressing your remote to the TV using different codes. I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at [email protected]!
You can lookup the different codes here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Feb 27, 2014 | DISH Network Televison & Video
Volume and mute buttons are not working
Do you have fresh batteries in the remote? You did not provide your TV brand so I can't provide you the codes for your specific TV. Below I have provided instructions on how to perform a power scan. If this doesn't work, you may need a new remote.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the redTV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 17, 2011 | DISH Network IR Remote Control
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
May 31, 2011 | Sony RMYD028 Remote Control
We had a new receiver installed sunday and that nite at 7:30 my remote quits working.I called in and a tec walked me thru the fix and the next nite the same thing happened.that happened for 4 nites.Works...
Hi I_yngbld,my name is Mike Houston of DISH Network and I was going over your post and seenwhere you're remote is having a hard time reading the IR sensor. Please makesure there is nothing like a computer tower close by or anything that couldcause interference, once the receiver is clear of any interference try theremote again. If the issue still persists please e-mail me at [email protected]
Apr 01, 2011 | DISH Network ViP722 DTV Receiver /...
I need a remote control code for tp 3730
tony_ballard
I could not find a code for that TV brand but I have provided instructions on performing a power scan to possibly find a code with your DISH remote that will work for your TV. I hope this helps.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  5. After the television turns off, press and release the OK button.
Ray Calo
DISH Network
Mar 21, 2011 | DISH Network IR Remote Control
My friend has a Vizio model E470VA and Dish network. But the Dish remote will not control the volume / mute on the tv reliability. The on/off button works perfectly. Remote has been replaced also...
Dec 18, 2010 | DISH Network IR Remote Control
Dont work volume or turn tv on or off
gwtammy
I have provided instructions on how you can program your remote to your TV. You did not specify your TV brand so here is a link with the codes for most TV manufacturers. I hope this helps.
Link with TV codes:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Remotes: Basic (Television Only)
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Oct 24, 2010 | DISH Network IR Remote Control
The Volume function on my remote doesnt work, you ...
Hello, my name is Michael Hurst with DISH Network. Sounds like the remote isn't programmed to your TV. You could use a remote code for your TV. To give you the correct remote code we would need to know the manufacture of your TV and the model of remote you have. You can also try a Power Scan and cycle through different codes that are available. Here are the steps for a Power Scan: Withthe desired equipment on, press and hold the correct Mode button until all modebutton backlights illuminate, then release. Press and release the Power button. AUX Mode: Before pressingand releasing the Power button. Press 0 for a TV, Press 1 for a VCR/DVD andPress 2 for any other device. Then Press STAR (*). Press the Up button once asecond while pointing the remote at the desired equipment. If the code for theequipment comes up, the equipment will power off. Press the POUND (#) button. Ifthe code entered is valid for the remote, the mode light flashes three times.
May 19, 2010 | DISH Network IR Remote Control
What are the Dish Vip 211k receiver codes
Hi turk0050 my name is Mike Houston of DISH Network, there are manydifferent codes that go to our DISH remotes. There are steps that will allowyou to program your DISH Network remote to your TV. The first step is to holddown the clear TV button for 6 seconds and then press and release the red Powerbutton. Then press and release the Channel Up button until the TV turns off.Once the TV is off press the # button and tries your volume and mute button tomake sure the remote is working. I will send a link to help with the setup ofthe remote. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Apr 26, 2010 | DISH Network ViP 211 DTV Receiver
My volume and mute button dont work on my sky remote
panasonic
please follow the steps below:
TV
RED + SELECT
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 06, 2009 | Universal Remote Control Remote Control
Televison & Video Logo
79 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
