The numbers to enter maintenance mode are not responding. Am Ernest +260966858453
SOURCE: Maintenance Mode
Les,
you dont have to compute any numbers.
Simply change the printhead.
If you receive an error starting with 4 again, this means that the "new" ph is faulty, too.
Save lifetime and energy and buy a new dcp 130 or 135 because this is cheaper.
SOURCE: how to get into the service mode
press button C & 8 at the same time to show u the error no. its the error no that will let u know the fault type.
SOURCE: I want to reset the
Hi James,
You need to change the Waste ink tank to reset the counter. There is no other way to do it.
-Amar
SOURCE: I just need to know two things...Is the adj app
just download service manual you get it all function
You can access the following by hitting the menu key
1. Enter the maintenance mode [>>Maintenance].
2. Press the OK key. [>>Maintenance?] will be displayed.
3. Press the OK key twice. The counter for each component is reset immediately.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
Completion
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function). Also see note at bottom.
Purpose
Method
Completion
