Question about Home
Have a cab50 auger motor not coming on so no pellet feed replace motor still do not work
Posted by kim vaughn on
5 Related Answers
mrgreenz
Daniel Arellano
  • 962 Answers
SOURCE: My pellet stove will start
You need to replace the auger motor. Go to fasco .com they may have one. Or enco.com I have a pellet stove and i have replaced both the auger motor and the motor that turns the hopper.
Posted on Nov 20, 2008
Anonymous
SOURCE: pellet stove auger motor
What's the matter with it? I can tell you how to overhaul and rebuild it.
Posted on Jan 13, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 01, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
Anonymous
PRESS H THEN TROUBLE THEN START THEN HIGH 6 THEN LOW 1
THEN PRESS BLOWER & HIGH FOR 3 BEEPS
Posted on Feb 22, 2010
My auger wont feed the pellets - I can hear it turning but nothing is feeding
Have you checked to see that the auger is not blocked? Or the pellet hopper is not blocked ? if the auger is turning then it has to be that something is blocking the pellets from getting in to it.
Dec 18, 2017 | Heating & Cooling
Stove will run for 5 to 15 mins and the auger will stop feeding.
Are the pellets getting stuck or jammed in the auger? Take a look at this website and perhaps it will give you some ideas to look at:
http://www.pelletstovefires.com/pellet-stove-problems.html
Nov 22, 2017 | Pool & Spa
No flame. The auger works fine and the pellets are feeding in. There is no fire to burn them.
Do you have a user's manual? Most pellet stoves need to be lit before starting the auger to sustain the fire.
Feb 10, 2017 | Cars & Trucks
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Pellet stove
vacuum switch helps all to work and power supply if more than 2 bends in the exhaust can b a problem to there is a intake air lever on the back of some that allow more or less vac pressure in to the chamber auger will not turn if door is open to create the vacume
Dec 02, 2013 | Heating & Cooling
Pinnacle Pellet stove augre gets stuck
hmm, could be low power to the motor, heavier power cord, or it's possible the auger needs new bushing/bearings, wiggle the auger to see if it has any play in it OR it's fussy about the size of pellets it made to feed. please send pictures and or results.
Jay
Jun 08, 2017 | Pool & Spa
Pellet stove augur starts and will start burning and then it back up pellets will not come out the augur will not spit out the pellets and they just get chared
auger may be jamming or motor is starting to go unplug unit and open back and oil auger motor and check operation- auger may not be sitting right in feeder tube also try a different pellet some pellets are bigger(sizes vary from company to company) which sometimes jam at feeder in hopper
Nov 26, 2009 | Ruud UBHC Air Conditioner
My pellet stove will start but the auger will not drop pellets. What should I do.
Nov 20, 2008 | Kitchen Ranges
Home Logo
184 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
