Question about Avital Vehicle Parts & Accessories
How do I fix my avital one button remote car starter after battery installation
Posted by Jason Mckee on
5 Related Answers
Anonymous
  • 34 Answers
SOURCE: im about to install a
the one you need to use is the wire that shows a 12volt power in cranking posision
Posted on Jan 09, 2009
Anonymous
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
Anonymous
SOURCE: car starts without using remote starter button
TIMER MODE!!!! Remote Start the vehicle with the fob...and open the door and press the brake pedal. Solved. DONT PRESS LOCK AND UNLOCK AT THE SAME TIME...EVER, this engages Timer Mode....
Posted on Dec 22, 2009
Wilson Martinez
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
logosc75
Larry Spears
  • 625 Answers
SOURCE: can an avital 4113 remote starter be installed in
Yes, just program the wait to start to 15 seconds.
Posted on Sep 16, 2010
Starter does not work when cold outside
Have look at your main battery connections
Nov 09, 2015 | 4113 One Button Remote Start With...
Ford f150 Avital 4103
You can put an amp meter on the battery, an amp clamp meter is easier and safer or a multimeter with 20 amp rating or better, find remote starter unit, find fuses for unit red wire on most starters is 12 v constant, you can put amp meter between the Avital fuse but there may be multiple Red wires or run the ampmeter on the battery + terminal through the ampmeter, DO NOT START THE CAR with the meter connected, just hook it up and close all the doors and wait 2 hours for all the car computers to reset and idle, record your amp readings, its tough to say what your truck actually drains per hour, I am guessing under 60ma is ok, remember when you open the car door you will activate the SJC computer "smart junction box in most Fords and it will drain current for a little while, disconnect your Avital and then see what the current is after an hour, remember most Digital volt meters shut off now after 5 minutes and you have to push buttons or flip knobs to activate them, doing this may disturb the current reading tests because you might open the circuit , try an old analog amp meter if you can find one.
Mar 01, 2014 | Avital Vehicle Parts & Accessories
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
5103 Not working after dead battery
Your vehicle requires a data/immobilizer interface that controls the door tirggers, brake shutdown, remote starter sequence, etc. When you lost power, the interface lost programming. it need to be reset.
Feb 04, 2014 | Avital Vehicle Parts & Accessories
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
I bought a used Ford Crown Victoria with an Avital system installed and the seller told me the way the system was setup was using the keyless entry to unlock the doors as the only way to start the car
The way the system was set up?! Here is what it sounds like. If you cannot start the car with the key but, you can start it with the remote starter means two things; the car has a starter inhibit installed and it's active or, the starter wire is cut and isolated from the ignition cylinder and the remote starter is connected to the starter side only of said cut wire.
About the keyless entry; Ford vehicle have a battery save mode that, after 10 minutes or so, the GEM module goes to sleep. The installation of a keyless entry system on these vehicles require connections at the unlock, driver's door ajar/latch wire and factory alarm disarm and programmed to double pulse. This will wake up the GEM and unlock the doors.
Nov 19, 2012 | Avital Vehicle Parts & Accessories
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
Both remotes failed to either start the car or lock or unlock the car this evening.. after entering with the key the old fashioned way, the car will not start with the key,the starter turns over fine...
no reset button, sorry. If the starter is turning over, then it's more than likely not an alarm or keyless problem. if it was even connected, the starter kill feature is used to "cut" the starter wire from the ignition and the starter itself, and if you say it's turning over, that's where i get my answer for it not being the avital. of course there could be more to it, remote start added, and the type of car make a huge difference, could be a bypass module for bypassing a factory security system, so without any more info, that's all i can give you. hope this helps, dave
Nov 10, 2010 | 2101L Keyless Entry
Vehicle Parts & Accessories Logo
276 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
gludwick2
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
