Question about Alpine Car Audio & Video
SOURCE: Alpine MRV-1507 Running 2 Alpine Type R 1242D
If you are not using a capacitor at this point, i would recommend getting a 1 or 1.5 farad cap and adding it to the system to take some of the strain off of your electrical system.
next on the agenda is your speaker wiring, the mrv-1507 runs around 900 watts at 4 ohms bridged.. your speakers (I believe) have dual voice coils, so 4 connections total, if you are running 2 of the speakers this will be 8 connections total, in order to match the impedance of the amp you will have to wire the speakers in series/parallel. if you have never done this before, it is easy and will ensure you are running the set at 4 ohms (which will make a huge difference in and of itself).
take both speakers out, you are going to want to wire the positive from one coil to the negative of the other on the same speaker. do this to both of them, this should leave you with one positive and one negative unused on each speaker. now you want to hook both of your free negatives together and run it to the negative on your amp, then repeat the process with the positives.
this is going parallel (4 ohm / 2 coils = 2ohm) and series (2ohm x 2 bridged coils = 4ohm).
now your rms on the speakers is 500 watts each, so matching them to a 900 watt or so amp should work great.
when you are installing the wire, make sure the gauge is correct for the length of run and for the wattage, also connect your power directly to the battery or to a distribution block that is capable of handling the power. in all of my installations i run 0 gauge wire from the battery to a distributor block i mount on the firewall, then i run anywhere from 2 to 6 gauge wire to the amp depending on the wattage and run length.
for your purposes, if the length of wire from the battery to the amplifier is 13 feet or less, 4 gauge wire should be fine, if it is between 13 and 20 feet, i would consider buying 2 gauge wire for the install.
you didn't mention what size your fuse is, but i am going to assume it is 90-100 amp, for a 1000 watt amp i use a 150 amp fuse. if you can find a 130 amp fuse it should work fine.
a major thing to remember when installing an amplifier is that your vehicle's charging system was never meant to accommodate large loads for an extended period of time. connecting direct to the battery, using a stiffening capacitor, and properly matching impedance will go a long way towards helping to overcome the limitations. in the future, if you decide to go all out on this project, i would recommend getting a high output alternator, a battery isolator, and a deep cycle battery for the audio equipment. this will insure that you never kill your primary battery, and that you won't run into issues down the road with your vehicle electronics.
i hope this helps you out, if youhave any further questions, feel free to ask.
trin
Posted on Nov 15, 2007
SOURCE: wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Posted on Jan 26, 2008
SOURCE: blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Posted on Mar 17, 2008
SOURCE: How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Posted on Jan 12, 2009
SOURCE: i have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Posted on Feb 23, 2009
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS. You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
