Question about Frigidaire Kitchen Ranges
How to remove glass top on fridgidare Fes388wgci
Posted by Vincent trama on
Chris Huff
    Top Expert:
  • Frigidaire Master
  • 6,289 Answers
There are screens under front of top just above door. Remove those and top should lift up and remove
Posted on Nov 09, 2018
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Fridgidare PLES389DCB top left rear element stopped heating after a bright flash from under the top. Looked like it shorted out, now the right rear element flashed undr the top. it didn't stop working yet...
hmmm..flashes under the top(as in the hood)..I suspect you have some faulty wiring. Only way to find out..
unhook power
remove hood/top
visually inspect wires for fraying or cuts(sometimes critters will do this too)
report back, ok?
Feb 29, 2008 | Kitchen Ranges
BROKEN RANGE GLASS ASSEMBLT REPLACEMENT
Third time today. Remove all burners ,everything you can remove from the glass top, then use two small screwdrivers as tyre levers go around the edge and the glass top will lift off.
Apr 17, 2014 | GE Kitchen Ranges
Fridgidare top loader won't drain - no clog, new pump and timer
Yes...I would have mentioned lid switches to you. Dryer Doors and Washer lid switches can become a problem. They are constantly used and in some cases deposits enter the switches and effect the operation. Slamming a lid or door also damages switches and contacts. Glad you found the problem.
Dec 18, 2013 | Frigidaire Washing Machines
Help- fridgidare dishwasher will not empty
Hello Monica Ward - Are you referrin that the dishwasher will not drain?
If so, when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, pits, etc. You should simply be able to grasp the handle, lift out, empty and place it back. Is the unit making a grinding noise? If it is, then contact a professional because you may possibly have a defective drain motor.
Feb 08, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Fridgidare dryer model GLGQ2152ES3 runs but does not heat how do I get inside front or back to check the ignitor. It doesnt light (i think)
ok, you can remove the small screws below the kick panel below the door on the front. that will gain you viewing space to watch and see if the ignitor is even glowing, if it is then you most likely need gas valve coils, or to turn on the gas.
if the ignitor is not glowing at all you will need to do some testing on the safetys and thermostats within the dryer. they are all closed at rest so you should have continuity through them. there is the operating stat on the air duct blower housing in the front of the dryer. there is also a hi limit that is on the rear housing of the unit that you will need to remove the top of the dryer to view and gain access to..
those dryers have been a pain and the rear hi limit is especially susceptible to poor venting practices so very common today, and the higher operating temps caused by the poor venting..
best of luck..
May 20, 2010 | Dryers
Fridgidare leaks inside
most likely your defrost drain is clogged and it is overflowing. look on back of box. there may be a removable p- trap.
Jul 25, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Moisture developing between the glass on the ovendoor
when the oven comes new ,,you must burn the coating of for about an hour..a form of food grade rust proofing..let unit bake at 400 for 55 to 65 minutes empty
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning inside glass door, kitchenaid range
you do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Oct 30, 2008 | KitchenAid KGST307 Gas Kitchen Range
Fridgidare gallery oven malfunction?
A spill dripped down on the inside of the glass of the oven door. How can it be cleaned and what would it cost?
Oct 23, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
104 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
