Radio Communications Logo
Question about Radio Communications
Got a 088 cannot transmit continual beeping with tx and rf flashing
Posted by robert haddow on
3 Related Answers
Anonymous
  • 24 Answers
SOURCE: NO TX RF POWER AMPL.
replace the rf block in the back of the case you can get the sam at raymarines.com
take the case apart look at the back of the radio there is a brass cover over the part read the part no# (av-6?) or a mitus part go on line to find part raymarine charges big bucks for parts
Posted on Jul 14, 2009
Anonymous
SOURCE: I have a tk-390 portable radio and it continues to
I am having the same problem. Does anyone out there have a solution?
Posted on Dec 07, 2010
Anonymous
  • 98 Answers
SOURCE: my connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
Posted on Mar 14, 2013
When trying to transmit the meter displays " RF Out" and doesn't transmit what is causing this?
Many things. The TX relay may be bad. The RF output transistor may be bad. The driver transistors may be out, The mike cord may have a broken wire. The antenna may have corrosion at the connector.
I have a connex cx-4300 hp cb it will receive but won't send how do I fix this problem
Is there any RF being transmitted, to a nearby radio. also does the TX/RX led change.
There are many scenarios on this..
Loose/cold solder joints on the board.
loose diode on solder side of the IF area..
Bad RF transistors from High SWR..
if you can provide more info.
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
My connex cx3300hp wont transmit
2helpful
Radio recieves but won't transmit
If it will TX to a radio next to it. CHECK YOUR SWR's and replace the final rf transistors. Having a cb shop check them SHOULD be FREE! and if the rf final transistors are bad. A shop should bench test it for FREE, and shouldn't cost no more than $25 to fix. If they do have them call us. transistors are cheap.$2-5 each max.
I removed my Roger Beep from my Eagle Sidewinder 400, It still receives but will not transmit. What do I have to connect back up for it to start transmitting again? I'd be Thanking you for any help.....
If the radio is not going into TX, then you have not connected the TX line back up,
If there is no audio when you TX you have left the audio wire off.
The radio usually needs 4 wires.
TX (Puts radio into TX)
Audio (this carries the audio from the mic into the modulator)
Screen (ground cable (earth))
RX (not as common these days)
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Constant beep, channel number and tx flashing
Ok this problem is caused by the spring mic jack
Getting rusty
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
