Question about Amana Washing Machines
I have an Amana washing machine ntw4515fw1. It will not run,and has no lights showing. Seems to have power to the plug,the water solenoid makes a sound when the machine is plugged in.
Posted by Nenok on
Chris Huff
    Top Expert:
  • Amana Master
  • 6,289 Answers
Most likely a control board problem if no lights at all are on.
Posted on Nov 08, 2018
5 Related Answers
Anonymous
SOURCE: Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
If you are not sure what you are doing, call out an engineer and have the job carried out properly with safety testing at the end of the job!
Posted on Dec 09, 2007
Anonymous
  • 734 Answers
SOURCE: ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
Anonymous
SOURCE: amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Posted on Dec 24, 2008
Anonymous
SOURCE: Smart drive washing machine not filling properly?
There is a valve under the top of the cover were the bowl is This valve has a spring in it and this spring and valve can get stuck shut this stopping the speed of the water entering the machine it may stop it all together
Posted on Apr 03, 2009
Anonymous
  • 103 Answers
SOURCE: GE Ice maker cycles but no water to machine. I
Replace I/m
Posted on Oct 17, 2009
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
I bought an older 842 washing machine. It has been sitting for awhile so I cleaned out the filter. At first I did not get the plug back in and water ran out and the inlet fault light came on.
Sounds like either the small filter at the inlet solenoid valve or the solenoid valve itself. Either way you are going to have to get inside the machine to get to the inlet valve.If no water is coming through the soap draw then it can really only be at the valve OR the inlet to the soapdraw is blocked (again - need to take off the top to look) Make sure power is disconnected before you do. The flashing red light after 30 seconds or so is just letting you know that the drum has not reached certain water level in the appropriate amount of time.
Good luck
Aug 28, 2015 | Miele Washing Machines
Where is the cold water valve on amana washer
the cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
May 10, 2017 | Amana Washing Machines
Why doesnt my washer put out cold water
either the hose screen inside the fill hose is plugged with lime/rust/etc. or the water solenoid is defective or not getting power from the controls,on some fill valves there is a thermistor that senses water temps as it fills and this part could also be defective,you can test this valve with a cheater cord to see if it opens,or unplug the machine and use an ohmmeter to test the solenoids coil for continuity,if good plug it in and check for voltage(normally 120 volts A.C.)on the solenoids terminals during the fill cycle
Nov 19, 2012 | Amana Washing Machines
Washing machine seems to have a water block
Sounds like a solenoid valve fault. Does it start turning and act like it's washing even though there's no water inside? If so check pressure chamber and switch
Apr 22, 2012 | Washing Machines
Water entering the machine and not stopping
Hi, check water solenoid valve again, or give it a little tap, sometimes they get stuck, when you remove plug, if you had a timer problem, water would stop, your water solenoid valve have to be faulty, if you purchase it, you should return it. if it were a used one it's defected. the only other thing is if you have high water pressure in your house/building, probably that could force it open, but most unlikely, you should check, but first check water solenoid valve, it could be a mechanical fault, inside of water solenoid valve, you can remove water solenoid valve, put it apart and make visual check of plunger and all other parts inside of valve, if same problem continues, replace water solenoid valve. let me know, if your problem continues. Good luck.
Aug 19, 2009 | Washing Machines
No water on cold wash/cold rinse setting
Tip1. Make sure your cold water turnoff is turned on all the way off before you check water screen. It could be clogged with sediment located inside threaded cold water hose connection.If clogged scrape clean or replace screen.Reconnect cold water hose and turn cold water supply all the way on. Tip2. Electric water solenoid could be defective or simply have a loose wire on the plug of the solenoid or loose plug / wire on mode switch.
Jan 16, 2009 | Kenmore Washing Machines
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
189 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
