Question about GPS
How to reset 2015 Captiva,s GPS to current time. I have upgrade to maps but the current date shows 2061, time can vary considerably but generally about 9 - 10 hours behind current time.
Posted by Peter on
5 Related Answers
Anonymous
  • 20 Answers
SOURCE: Backup Streetpilot C330
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Posted on Jan 20, 2009
Anonymous
SOURCE: need upgrade on GPS sanyo #NVM-4070
I just found out there is only one solution to this problem. We have to buy a new GPS. A customer service Rep just told me that there are no updates available. Call 1-800-421-5013
Posted on Mar 10, 2009
Anonymous
SOURCE: jensen nvx200 gps
http://v7support.com/gps/Download/USA/Map_Files/North_America/v200701_Small/
go here to download which states you need or all of them..they are fbl files..
retirednow
Posted on Mar 28, 2009
Anonymous
SOURCE: no change time
You will need to backup all of your tracks, waypoints and routes to your PC. With the unit off, hold down the page, enter (joystick), and find buttons for 5 to 7 seconds while power up at the same time. Then go outside and let the unit get a fix on the satellites. This will fix the date problem. Once done go to the main menu and select setup and the system. Make sure WAAS is disabled. If you enable this option the date will get messed up again and you will have to do this all over. There was supposed to be a firmware upgrade that fixed this problem, however I found after flashing the firmware update, the date problem still occurs if WAAS is enabled.span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Posted on Jun 20, 2009
Anonymous
SOURCE: Meos GPS Navigation Module with UK+EURO Maps haw
iF U CANT GET TIME TO CHANGE TO SAME TIME AS THE HEAD UNIT. IN THE SATNAVE SOFTWARE U NEED TO GO TO MENU / GPS HARDWARE/ SYNC TIME. THIS WILL SET THE SATNAV TIME TO SAME AS HEAD UNIT SO SET IT FIRST
Posted on Aug 11, 2010
How to upgraid my device?
If you're refering to upgrading your Navigation software, QuickGPSfix data and/or your current (out-dated) map, you can do it by connecting to the TomTom website (www.TomTom.com) using the TomTom HOME or MyDrive Connect software, depending on the model/version of your GPS device.
If you're refering to upgrading your GPS hardware/equipment, to have more capability/features, the device is not hardware upgradable, except for adding/using an SD card with a higher storage/memory capacity (to store more info/maps, etc.) ... provided you have a GPS device with an SD card slot.
You'll want to consider buying a newer model with more capabilities / features than what you have now.
May 21, 2016 | Tomtom XXL GPS
My gps doesnt show all the streets
Sometimes it will not all the streets, especially main streets, unless is zoomed in, try the zoom feature in and out, or three 3 d or 2 d feature.
Jun 11, 2011 | Garmin nuvi 1490T GPS Receiver
Nuvi 285WT GPS Receiver: Road I'm on doesn't show in general map mode ... o...
Try resetting the unit. If your address or the road your driving on isn't show - try resetting the unit and then on the lower right corner click the space there. Some roads I have noticed do show and some sadly do not.
May 05, 2010 | Garmin Nuvi 285WT GPS Receiver
Our state agency purchased 300 Nuvis for our police cars. I am the training officer and am being asked what benefit otaining the $70 upgrade would be. Is this urgent? Is is needed? Could we get a free...
It depends on how long you have had them.
I have heard that a buyer is entitled to a free upgrade if the unit is new and the upgrade is requested within a certain amount of time.
Apparently there the firmware in the unit records when the unit first obtains a satellite lock and that date is is used to determine how long the unit has been in operation. I'd check into it right away.
The problem is you have so many units and it takes about an hour to upgrade each one. So, its not going to be a quick process.
You need to see what map is already on the unit by selecting the tool icon, then system, then maps and then "map info".
The 2010 maps are already out. Newer maps means you unit is more up-to-date with current roads that have been added.
No it is not urgent but if you can get it for free, then you may wish to consider it.
- Jim
SHARCNET-USA
http://www.sharcnet-usa.com
Aug 11, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
How do I reset GPS to original setting
hi,
thank you for using Fixya.com
click on this site you be directly connected to the manual including to solved your problem how to reset your unit general..
http://www.scribd.com/doc/249380/TomTomONE-Manual
hint go to page 39 of the page GENERAL Reset guide.
May 21, 2009 | Magellan Maestro 3200 GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
New areas in different cities re not into my gps memory
contact your map provider, maps are quite out of date sometimes,,, my mapping provider done a free upgrade.
lcbr1911
Mar 19, 2009 | Nextar X4-T Car GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Sat nav
how do i upgrade my gps 200w map
Oct 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
584 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
