Question about HP Televison & Video
I have a HP MD5820N tv and it started making a loud humming noise and the colour went all dark and flickering and now will not turn on, the red lights flashes twice under the light bulb and thermometer pictures
    Top Expert:
  • HP Master
  • 76,416 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview./
Posted on Nov 08, 2018
5 Related Answers
Bill Heronemus
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
Anonymous
SOURCE: humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Posted on Aug 18, 2008
Anonymous
SOURCE: HP Pavillion dv6000 - dark screen, no power noise, but power lights are on
1) Turn off your laptop.  2) Remove Power supply.  3) Remove the battery and put it back again after 1 min.  4) Put power back and restart.
This should solve the porblem ! I have had it several times.
Posted on Nov 29, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
Anonymous
  • 3 Answers
SOURCE: I have a Samsung TV # HLP6163WX/XAA. A loud
I also have a Samsung HLP6163W 61in TV,had the same problem had to replace the color wheel. Went on youtube showed us how to do it our self. Saved a lot of money very easy. Good luck!
Posted on Jan 19, 2010
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Loud humming noise and black line
Sounds like the color wheel has broken. Remove the color wheel and see if its broken. Usually a broken wheel will cause those symptoms.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Hp md5820n when is about to turn on it make a weird sound and then both red lights are flashing, i already have replace the lamp
If it loud humming noise when you turn it on - touch the side of the TV. If it's vibrating enough for you to feel it - you have problem with color wheel. It could be separate replaceable part or it could be integrated part of optical engine.
If you hear buzzing sound that goes off and then back on couple of times - could be bad lamp (even new one), bad connection between lamp and ballast (lamp power supply), or bad ballast.
If you have to replace optical engine and you out of the warranty - don't bother with repair. It would be not less than $600-$800. Invest in new TV.
Mar 10, 2010 | HP Pavilion MD5020N 50" DLP HDTV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
TV Flikers and StandBy Light Flickers
Your pdp panel sounds faulty - Count the red flashes this is an error code.
Nov 13, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Televison & Video Logo
Top HP Televison & Video Experts
Edward Easley
Edward Easley
Bernie Scott
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
