Home Security Logo
S
Sylvia Sopkiw Posted on Nov 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lock my keys in the safe. The safe don't open because the batteries line is eroded l need someone to come to my house and open the safe. My phone number is 9103467573.
Honeywell safe
Thomas Waite
Level 1:
Habit-Forming:
New Friend:
  • Contributor 38 Answers
  • Posted on Nov 08, 2018
Thomas Waite
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
38
Questions
0
Helped
14301
Points
67
Just clean the metal parts inside the battery compartment with some isopropyl alcohol and try to scratch off the brown corrosion with sandpaper.
ch.vijaysagar
Level 2:
Sergeant:
  • Expert 272 Answers
  • Posted on Nov 07, 2018
 ch.vijaysagar
Expert
Level 2:
Sergeant:
Answers
272
Questions
0
Helped
113318
Points
902
NEED HELP WITH YOUR DIGITAL LOCK? Most digital lock problems are related to low, dead or Non-Alkaline batteries. For all SentrySafe models, we recommend the following:
  • Refrain from using rechargeable or Non-Alkaline batteries.
  • Use quality name brand batteries.
  • All batteries have expiration dates on them. Ensure those dates are as close to 10 years out from current year as possible.
  • When changing batteries do not mix brands (i.e. all 4 batteries should be Duracell) or mix old batteries with new batteries.
FOR SENTRYSAFE MODELS THAT BEGIN WITH A3, A4, A5; J3, J4, J5; S0, S3, S4, S5, S6, S7, S8, SB, SBW, SC, SW; J3, J4, J5; L0, L3; V: Don't know your model number? Find it here.
  1. Slide open battery cover located just below keypad.
  2. Insert a paper clip or pen point into small hold in the cover.
  3. Push in while sliding cover to the right.
  4. Remove battery holder.
  5. Insert 4-batteries as indicated (Do not use rechargeable, or Non-Alkaline. Do not mix old with new batteries or mix brands of batteries).
  6. Put battery hold back into safe.
  7. Slide cover back into place.
Slide open battery cover below keypad. FOR SENTRYSAFE MODELS THAT BEGIN WITH CS, CSW, DA, DS, KS, KSW, MS, MSW, OA, OS: Don't know your model number? Find it here.
  1. Check bottom edge of electronic lock and if equipped with shipping screw, remove and dispose of.
  2. Turn electronic lock clockwise (right) and remove.
  3. Insert 4-batteries as indicated (Do not use rechargeable, or Non-Alkaline. Do not mix old with new batteries or mix brands of batteries).
  4. Replace the electronic lock and turn counterclockwise (left) to reattach.
Turn electronic lock clockwise. FOR SENTRYSAFE MODELS THAT BEGIN WITH SFW082B, E, F, G; SFW123B, E, F, G; SFW205B, E, F, G; STW123G; STW205G: Don't know your model number? Find it here.
  1. Pull out the battery drawer on side of electronic lock to the right.
  2. Insert 4-batteries as indicated (Do not use rechargeable, or Non-Alkaline. Do not mix old with new batteries or mix brands of batteries).
  3. Replace the electronic lock by sliding in to the left.
Pull out the battery drawer. FOR SENTRYSAFE MODELS THAT BEGIN WITH SFW123T, U; SFW205T, U: Don't know your model number? Find it here.
  1. Remove battery compartment from inside door.
  3. Replace battery compartment.
This safe has a Battery Auxiliary Override-
  1. If battery is low and unable to operate open, use Battery Auxiliary Override.
  2. This should not be used as a primary means of gaining entry into safe.
  3. Open the silicone cap found on the side of the electronic lock.
  4. Insert a 9 volt battery into slot.
  5. If attached properly, you will get 3 chirps from electronic lock.
  6. Touch center of electronic lock to wake up keypad.
  7. Enter 5 digit code, and turn handle to open.
  8. Once opened follow instructions above to change batteries in compartment located inside of door.
Remove battery compartment from inside of safe door.Enter 5-digit code and turn handle to open.
FOR SENTRYSAFE SECURITY MODELS THAT BEGIN WITH ESB; PL: Don't know your model number? Find it here.
  1. Insert override key, and turning dial to unlock position will be required to open door.
  2. Remove battery compartment from inside lid of door.
  4. Replace battery compartment.
Remove battery compartment from inside lid of door. FOR SENTRYSAFE SECURITY MODELS THAT BEGIN WITH QAP1E, QAPBE1, QAP2E, QAP2EL: Don't know your model number? Find it here.
  1. Insert and turn clockwise (right) override key to unlock position will be required to open door.
  2. Pull out battery pack (keep battery pack connected to wires).
  4. Replace battery pack cover.
Pull out battery pack. FOR SENTRYSAFE SECURITY MODELS THAT BEGIN WITH CA; HL: Don't know your model number? Find it here.
  1. Unscrew and remove override key lock cap.
  2. Insert key and turn counterclockwise (left) to unlock door (notch on key in upward position).
  3. Open door, remove battery compartment cover in direction arrows are pointing.
  4. Insert 4-batteries as indicated (Do not use rechargeable, or Non-Alkaline. Do not mix old with new batteries or mix brands of batteries).
  5. Slide battery compartment cover back into place (make sure cover is locked in place).
Override key lock cap. FOR SENTRYSAFE MODELS THAT BEGIN WITH X: Don't know your model number? Find it here.
  1. Remove cover to override key between dial and keypad.
  2. Insert key and turn counterclockwise (left), then turn dial clockwise (right) to open door.
  3. Remove battery compartment cover in direction arrows are pointing.
Remove battery compartment cover. FOR SENTRYSAFE SECURITY MODELS THAT BEGIN WITH T: Don't know your model number? Find it here.
  1. Turn electronic lock counterclockwise (left) and remove.
  2. Unlock door with override key, pull handle down to open.
  3. Remove key hook plate located on backside of door by sliding upward.
  5. Slide key hook plate back into place (make sure cover is locked in place).
Turn electronic lock clockwise and remove. Slide key hook plate back into place. FOR SENTRYSAFE SECURITY MODELS THAT BEGIN WITH DH: Don't know your model number? Find it here.
  1. Turn electronic lock clockwise (right) and carefully pull away from mounting plate.
  3. Carefully position keypad on mounting place.
  4. Ensure no wires are between keypad and mounting plate to avoid pinching of wires.
  5. Turn keypad counterclockwise (left) to attach to mounting plate.
Turn electronic lock clockwise and pull away from mounting plate.
john h
Level 3:
Top Expert:
  • Honeywell Master 29,494 Answers
john h
Honeywell Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7555952
Points
193449
Wrong site notify locksmith
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Mar 05, 2008
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Anonymous
  • Posted on May 23, 2009
SOURCE: Have a honeywell security box
This means you need to change the battery use your key to open it up the battery compartment is under the top of the box with a slide off cover
Anonymous
  • Posted on Oct 10, 2009
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Anonymous
  • 3600 Answers
  • Posted on Nov 22, 2009
SOURCE: Door locked on safe
Brian We can't give advise on the safe but you can call the manufacture of the safe and if you have registered it they will help you otherwise federal law requires a lock smith to identify you and your information and your ownership of the safe before they will unlock it for you. This is to protect you or the safe owner and the lock smith from being sued and losing his licence.. There should be a sticker on the safe with a 800 number for you to call to get help. But you must have registered it first. They may have a way to verify it some other way but am not sure.
A1 Locksmith Burlingame
  • 170 Answers
  • Posted on Sep 18, 2010
SOURCE: CAN NOT OPEN MY SAFE,
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
1helpful
Detroit safe. How can I open it?
The number on the key housing may provide sufficient information for a locksmith to open it.
I have lost my keys during a house move
didnt specify brand --try notifying safe company and or notify a locksmith
I hav a amsec dl4000 safe and forgot the passcode and hav no idea where the 2 keys r. the batteries work tho, is there anyway for me to open it??
I knew someone who had a locking mailbox like that with keys when pass is forgotten or battery runs down, they could open with key. He registered it as directions said to do so you could order new keys, the old mailbox was also lockable and since owner died he had to throw it away as couldn't prove he wasn't thief. Maybe something there helps.
2helpful
Have lost keys for Micromark electronic safe and batteries are running down. Phone no for Micromark no longer in use Need new key or any help
A competent locksmith should be able to make the keys as long as you have the safe open and he can remove the lock cylinder(s).
2answers
Hardline safe lost key & battery flat
if you have lost the key -- then look on the face of the lock cylinder and see if there are letters and numbers on it,, ( key code ) -- take this keycode to your local locksmith and see if they could make the key. if the code is not there then take the safe down to your local locksmith shop and have them pick open the safe. now if the safe is mounted in your house and cannot be removed - then have a locksmith come out and pick open the lock and make new keys for the safe.
c...
3helpful
3answers
The batteries of my powersafe TR 36 are dead and I don't have any key. What can I do to open the safe? Urgent! Thank you in advance!
I know this post is months old, maybe you didn't open your safe yet or maybe someone else could use the advice.
The batteries are no inside the safe because of this reason, that you should be able to change them if they run dry.
Under the key panel is a long plastic panel. You can slide it to the right and underneath you find the battery compartment.
4 x AA batteries
2answers
Harldline safe not opening
Sure blame the poor kid.
Think about it, what good would a safe be if by pressing a few keys the combination was changed?
As with any combination safe you need to clear the combination by turning one, two or three times in the opposite direction before entering the combination.
Now say your sorry to your kid.
21helpful
3answers
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Top Honeywell Home Security Experts
Jay Finke
Jay Finke
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
