Question about Ricoh Office Equipment & Supplies
ERROR SC 672 IN RICOH MPC 6000 - Ricoh Office Equipment & Supplies
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
SC 672 is a controller error. So possible is tat the controller board is defective, in best case can be only the ram memory dimm's or the HDD but in most cases the controller board is dead.
Posted on Nov 25, 2018
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Posted on Dec 28, 2009
quennie732
  • 422 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
manzoorpudus
Manzoor Ahamed
  • 13 Answers
SOURCE: Ricoh sc 672 error on new machine
  1. Go to this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
  2. Go to System Settings
  3. Go to 5875
  4. Check the setting of SP5875-001. If the setting is set to "1 (OFF)",change it to "0 (OFF)".
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
Posted on Feb 29, 2012
pablo sandoovall
  • 435 Answers
SOURCE: ricoh mpc 2000 when machine starts without disply gives error codes. error message gives sc 202 in ark disply please give me detailed reply
Video might not help but this problem is due to the charge spring arching on the back of pcu, suggested fix eould be to restore spring to its original condition and add conductive grease to the charge plate on tge rear of the pcu. Hope it helps
Posted on May 03, 2013
SC 672 error apears in my ricoh 4002SP. what shal i do?
sc 672 Controller-to-operation panel communication error at startup
Possible Causes
? Controller stalled
? Controller board installed incorrectly
? Controller board defective
? Operation panel connector loose or defective
? The controller is not completely shutdown when you turn the main
switch off.
Check the setting of SP5875-001. If the setting is set to "1 (OFF)", change it
to "0 (ON)".
Peace to you all. my Ricoh mpc 6000 is showing this message sc992. please somebody help explain what it is and how to fix it. thank you.
Software error 3: Undefined An error not controlled by the system occurred (the error does not come under any other SC code
Ricoh mpc 350 error school 972 what is the resion Ricoh mpc 3001 error code sc 972 how I can fixed it
If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
3answers
Ricoh mpc 6000 sc540 error code
my reecho mpc6000 calur macing problem yellow toner add , pl help
3helpful
  3. Go to 5875
3helpful
2answers
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
9helpful
Ricoh 1045 error code sc 672, 961
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
