Question about Vehicle Parts & Accessories
SOURCE: I have a duralast jump
Adaptor for DURALAST BP-DL
Model HB-208b
Input AC 120V 60Hz
Output DC 12V 450mA
Posted on Jan 17, 2009
SOURCE: Jump and start unit is dead,how do I recharge this
These units have a meter on them that shows if it is full or dead. If it will not charge from an AC wall socket, the unit is probably no good. Check the charger that it comes with to make sure that it doesn't need to be reset. If it has no reset button, you may need to return it for an exchange.
Posted on Oct 06, 2010
SOURCE: Need a charger to charge
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Posted on Nov 12, 2010
SOURCE: I have an AC adapter
Hi and welcome to FixYa, I am Kelly.
You will not damage the battery.. you will destroy your AC Adapter charging system because the Jump start system will draw more amperage than your AC Adapter can provide. The Jump start system will charge at a minimum of 2 amps up to a maximum of 6 amps. Your AC Adapter will only provide 1.3 amps max. I.e it will go up in smoke.
Thanks for choosing FixYa,
Kelly
Posted on Feb 06, 2011
SOURCE: My Duralast Gold Jump Starter does not take a
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
Posted on Feb 21, 2011
Mar 29, 2015 | 600 AMP Jump Starter
Dec 04, 2014 | Cars & Trucks
Nov 16, 2014 | Cars & Trucks
Aug 25, 2014 | JNC300XL Jump-n-carry Ultra-portable Jump...
Jun 28, 2014 | Power Center Jumpstart 11-411
Feb 20, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Jan 08, 2009 | RoadPro Road Pro 12 Volt Dc Portable...
321 people viewed this question
