Nixon watch chronograph with 3 buttons on the left side
SOURCE: problem winding a Invicta Skeloton Mechanical Stainless Watch
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
SOURCE: Time
Hi Terena,
You're not a numpty! :O
Just go here:
http://uk.nixonnow.com/home/
MouseOver 'Support' and click 'User Manual', choose your model and follow the instructions to set your watch.
Hope this helps!
Chris (ziraffa)
SOURCE: Citizen Eco-Drive chronograph World. Top left button??
It is hard to say not seeing the watch as different watches has different means of push or screw-on buttons. If your watch has a 200 metres mark on dial, then it can be the Helium valve, but it's just a guess. To make sure you'll get the right info, paste this link into your browser:
http://www.citizenwatch.com/CUK/English/identifycaliber.asp
Find your movement caliber number and follow instructions.
If you can't find what you are looking for, upload full watch details here and I will try to find out.
Do not forget to rate, please.
SOURCE: Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
SOURCE: nixon super rover..need to know how to reset the chronograph
Pull the stem all the way out...like your setting the date. Then hit the upper button and that will move the hand 1 second at a time until it gets here you want.
