I installed a new black cartridge and the alignment page printed the same as it always does. it printed fine but when i try to print out something else it says "inkjet failed." i turned printer off and back on again to see if that would fix the problem and now it says "client-error-not-possible." how do i fix this problem?
SOURCE: Printer cartridge alignment
Hold "setup + options" at same time while turning off printer and back on while holding "setup + options"
SOURCE: cartridge alignment
So if the magenta or yellow are not showing up, it may mean you have installed an empty (or dried up) color cartridge. If you have it, put the "low" volume color cartrige back in and print an alignment page. If you don't have the cartridge, no problem, just print a page from Google. Don't worry about the alignment until you print from Google. See if color is even available. ZT3000 "Beta tester of "0"s and "1's"
SOURCE: HP psc 2110 Printer keeps
Switch off your printer. After one minute Switch on the printer. Remove the cartridges from the printer. Observe Cartridge contact points and clean it with rubber eraser carefully. Make sure that you never touch the contacts with your fingers or body parts. Touching may cause your cartridge reject by the printer. First install Black then the Colour. Place one paper in the paper feeder. I think your printer print an alignment page automatically after inserting the cartridges. After printing the page, place it the scanner (refer your printer manual) and I think you have to press the scan button. This will correct your problem. Every time you remove the cartridge and re-insert it, the printer will ask and print alignment page. you have to do the alignment every time. If you ignore the alignment printing you will get the same problem again and again. I experienced the same on some models.
SOURCE: align cartridges error
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
