Question about Precor Exercise & Fitness
My precor treadmill states:stuck button & will not go up in speed?
Posted by DynamixX Fitness on
  • J Scott Jan 25, 2019
    What model is it? Usually a stuck key is caused by a bad overlay or a stuck stop button.
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
Anonymous
  • 79 Answers
SOURCE: Increase speed button on Precor 945i not work
The problem is that the keyboard is damaged, and although some function buttons is likely that the form of this cut keypad. you should replace it. I leave the link here to a place that sold parts for treadmills.http://www.fitnessrepairparts.com/index.php
Posted on Feb 05, 2010
Testimonial: "Thanks for the information. I will try the website & see if I can find the part."
Anonymous
SOURCE: c956 precor treadmill
Hi
not to sound funny but are you sure that you have this tread set in the units (mpg/kph) that you require. i have worked in loads of gyms and its a common problem that people think the belt is running to fast because its set in kph and that thinks its in miles eg 9mph = 14.5kph
you can check and change the units in the club setting menu.
hope this helps :)
Posted on Feb 12, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Precor 9.25i Treamill scrolls message "button is pressed"
Press Enter,speed up and speed down simultaneously. Then enter to view error buffer . press quick start/pacer-stop simultaneously to reset error buffer log. Hope this helps
Posted on Apr 11, 2010
WarrierX
SOURCE: I have precor 9.31
I had that problem and solved it by removing the red "STOP" cover. The cover pushes against a switch. If the switch moves too far down and rests against the cover, it will be stuck in a lock position causing the error message. To remove the red STOP cover, remove the few screws behind the console. When the front cover is off, turn it over and unscrew the two screws that hold the red stop cover. Then push the cover out through the FRONT. Do not attempt to lift it out by the end with the screw holes. It iwll not pull out that way. Test the machine before screwing the panels back agian. The message should no longer show STOP KEY. Test the visible white small switch that you uncovered by removing the red flap. The message should stop when you press the switch.
I kept the red STOP cover off of the switch and screwed the panels back into place. The machine now works fine!
Posted on Feb 10, 2011
The incline on our Precor c964i is stuck in a high position (approx. 10% incline). Other than being on a high incline, the treadmill seems to be working fine.
Hi There,
Precor uses a pair of Triacs to drive the lift up and down. These triacs live on the lower board but are driven by the upper console commands via a serial link between the upper and lower. Most precor lift issues we see are related to the lower board but with Precor it could be an upper board or the CPU Chip that resides on the lower board or a failed Triac. Good Luck
Apr 07, 2017 | Precor Exercise & Fitness
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
seconds
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
Ramp is stuck
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is commonly caused by a bad overlay/keypad. The only solution to resolve this issue is to replace the overlay/keypad.
Please use your model and serial number to find the correct replacement at the following link: Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH net
Dec 27, 2013 | Precor EFX 546i Elliptical Version 4
Precor Treadmill 9.21si Error Code 26, what does it mean
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Jul 02, 2012 | Precor 927 Treadmill
On my Precor 956 i the Stop Key prompt appears
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Oct 24, 2010 | Precor 956i Experience Series Treadmill...
Apr 06, 2010 | Precor 9.21 Treadmill
Feb 03, 2010 | Exercise & Fitness
Exercise & Fitness Logo
454 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
