Question about GPS
Printmate 500 does not recognize SD cards - GPS
Posted by Rickard Ward on
3 Related Answers
Anonymous
  • 34 Answers
SOURCE: I put my SD card in and it does not recognize the
Maybe try reformatting the card (always in the camera and not with the PC).
If this does not work, it may be possible that you need a camera driver from Canon.
Posted on Aug 11, 2009
RamTek
Ramy de Jesus
  • 377 Answers
SOURCE: magellan explorist 500 wont recognize sd card. Is
  • Try to check the Sd card if its already formatted. because if the sd card is still not formatted it will not work to your GPS.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Posted on Feb 14, 2010
redgun10
redgun10
  • 18 Answers
SOURCE: will not recognize 2gb SD card
Well that other guy wasn't any help... Ok so my suggestion is to format the SD card.
!!!!BEFORE WE GO ANY FURTHER!!!!
MAKE SURE THERE IS NOTHING IMPORTANT ON YOUR SD CARD!!!
IT WILL BE COMPLETELY ERASED WHEN YOU FORMAT IT SO MAKE SURE THERE IS NOTHING IMPORTANT ON IT!!!
YOU CANNOT GO BACK AFTER YOU FORMAT YOUR CARD!!! ALL INFORMATION ON IT WILL BE GONE FOREVER AND REPLACED WITH NOTHING UNTIL YOU NEW PUT STUFF ON IT!!!
Ok first I should explain. Your SD card is probably in a different format your computer cannot read. For example SDHC. Instead of FAT16 or FAT32 which your computer can read. Your computer can't read a SDHC because it is in layman's terms in a completely different language than your computer can understand.
Now that we got that out of the way, the technical stuff.
1a. If you are on Windows XP: Click the start button and hit Run. On the new window that just popped up type diskmgmt.msc and hit ok.
1b. If you are on Windows Vista/7 Click on the start circle. And in the search bar at the bottom closest to the start circle type in diskmgmt.msc and hit enter.
2. Look for your sdcard in the top section of that window. Your computer's harddrive should be there too, and anything else with storage that's inserted. MAKE SURE IT'S YOUR SD CARD! It should be pretty obvious.
3. Right click your sd card on that list.
4a. If the option to partition it is there click on it and select either FAT16 or FAT-32.
4b. If there is no option to partition it then click on Format. Then format it to FAT16 or FAT-32.
That should have worked, if it didn't please let me know and I'd love to help you get your problem fixed. I love this website I'm having so much fun helping people lol.
Posted on Apr 11, 2013
My phone keeps telling me that my SD card has been removed but it hasn't been. I've tried taking it out and putting it back in but it keeps telling me the same thing
maybe because your phone don't recognize your SD card anymore. try to put your SD card to other phone and try if the other phone recognize your SD card, if the other phone don't recognize your SD card, the problem is in your SD card. you should buy a new SD card if that's the case. Also try to put a different SD card on your phone and you'll see your phone will recognize the different SD card.
Kindly rate this post. Thank you for your question and I hope I help you a lot.
Jan 20, 2012 | HTC Cell Phones
Does the canon pixma mp 500 printer recognize sdhc memory cards?
No, it doesn't support SDHC, the following card types are supported by Canon MP500 :
CompactFlash®, Micro Drive®, SmartMedia®, Memory Stick®, Memory Stick Pro ™, SD Card™ and MultiMediaCard™
And these are the cards which can be used with respective adapters:
xD-Picture Card™, Memory Stick Duo™ Memory Stick Duo Pro™, miniSD™ card
Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 17, 2011 | Canon Pixma MP500 All-In-One InkJet...
Magellan explorist 500 wont recognize sd card. Is there any type of card recomended i have tried 3 diferent cards in 2 diferent units but when i try to turn sd memory on it wont let me.
Feb 14, 2010 | Magellan eXplorist 500 GPS Receiver
Aug 11, 2009 | Cameras
It won't recognize the sd card adapter for mirco
THERE is a tweak with the cards you insert on your picture mate, to be honest these things dont recognize memory cards that are above 2 gig. they also dont recognize some brands. the most compatible as per experience is sandisk
Jun 23, 2009 | Epson PictureMate 500 InkJet Photo Printer
TomTom Go 500 doesn't recognize SD cardq
Tom Tom does not recognize the maps you download because they are not from them. Priority controlled.
Jul 23, 2017 | Tomtom Go Plus GPS Receiver
Lg kp 500 wont recognise sandisk micro sd!!! aghhhhh!!!
Some memory card wont be recognized by some phones or pc's. I also bought a sandisk card before and just found out (through reading online forums) that some don't actually work.
Feb 22, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LEXAR MICRO SD CARD WITH LG CU 500
I have found that only my 1 gig Micro sd card works, I also have a 2 gig and it does not recognize it at all. I have been told the CU500 only supports up to 1 gig.
Jun 05, 2008 | LG CU500 Cellular Phone
Unit Map
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
Feb 02, 2008 | Magellan eXplorist 500 GPS Receiver
MMC/SD Cards
In most cases they are interchangeable except for the security feature which you don't need for storage on your EM-500. SD cards are faster in read write department as also they cost more due to security featurtes built in. In Casio cameras Casio recommends SD cards but I have been using MMC cards very successfully.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
GPS Logo
64 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
