Question about Toys
I have a Mini Convergence VTOL, When i was setting it up using my Spectrum DX8 transmitter, the main two engines were turning the wrong direction. What is the procedure to correct us using my DX8 ?
Posted by Phillip Swiger on
1 Related Answer
Anonymous
  • 56 Answers
SOURCE: How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Posted on Mar 19, 2009
We can't get any reception at all with our LCD 23-231BB-G after moving to London. Using a One for All aerial SV9215 which had always been fine before. Re-tuning shows 0% signal strength. Any ideas? Tx
Yeah, you are getting lousy reception. If your antenna is directional re direct it to the direction of the stations you want to receive the most. Get an antenna amp to boost signals. Get a good directional antenna and mount as high as possible on mast for best signal reception. Make sure you have nada in the way of antenna and stations for best results.
Sep 03, 2017 | One For All Televison & Video
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
FX059 Radio Problem. Motor starts uncontrollably
YOU ARE ALL WRONG. This chopper binds better when the transmitter is turned on AFTER the helicopter. Centre all your trims. Turn on your heli. THEN turn on transmitter with throttle down. Try that. if that doesn't work, trim throttle down as well.
Dec 25, 2012 | Toys
RCA rear projection tv picture bowed to middle. Red Green Blue colors have been seperated on screen.
If I had to guess I would say it's either the DLP chip or the prism. Simply put the lamp lights the DLP chip which directs the light into a prism and then onto the TV screen. The prism or prisms are responsible for aligning the colors correctly. The DLP chip is essentially a million little moving mirrors which direct light
If you're at all comfortable with electronics you might want to open the TV up to take a look. You might get lucky and find something obviously wrong with the TV. Sometimes adhesives melt and parts slip out of place. If your DLP chip is blown there isn't much you can do. You're probably right that this would cost a lot to fix and not be worth it.
Jul 24, 2012 | RCA Televison & Video
Alighn ariel for digital tv
The best type of aerial for digital reception is to use a wideband aerial this will give you a better spectrum to receive the signal. To locate the aerial position, if you know in which direction your local transmitter is situated, then point the aerial in that direction. The best way to find out which way to point is to simply look around at any of your neighbours aerials & then aligned yours in the same direction. If you are using a spectrum analyser as your sattelitte finder then you can use this to find other frequencies in the signal range.
Sep 06, 2009 | Televison & Video
Convergence issue where can i get the part? can I replace my self?
the model number you have supplied is for a (wd-73733) is for a 2007 DLP type tv---this model has no convergence circuits--it uses an optical light engine---what is wrong with this set? my direct email is:
[email protected]
Aug 11, 2009 | Mitsubishi WD-73733 73" HDTV
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
1996 LUMINA REMOTE
turn ignition switch to OFF position , (all power door locks will lock and unlock) . use a fused jumper wire and jump programming connector to ground . see picture , press any button on one transmitter , door locks , fuel door and trunk lid release should activate in about 2 seconds , first transmitter is now programmed , repeat this last step using a 2nd transmitter , if only one transmitter is being used , disconnect jumper wire and test remote(s) . cheers . if procedure is to technical , ask someone mechanically inclined to help .
Jan 11, 2009 | 1996 Chevrolet Lumina Mini
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Main TV Goes On By Itself
If this happens often enough, it would be fairly simple to troubleshoot. Remove the batteries from your remote, if the problem persists, the problem is not the remote. Next step would be to unplug power to the transmitter, if the problem persists, the problem is not the transmitter. Next step unplug power to the receiver, this should undoubtedly make the symptoms stop, but try it anyway. If it does, it doesn't necessarily mean that the unit is bad. The remote extenders work on radio frequencies. If you have the paperwork for yours, look to see what frequency range it uses. Many other devices use radio, too. Cordless phones, especially the "frequency jumpers" constantly seek around for unused spectrum space and will jump right in somebody elses' space. If you have neighbors, their equipment can interfere with yours and vice versa. I've had microwave ovens with leaky door gaskets interfere with 2.4ghz signals. The new(relatively) incursion of home wireless broadband is another local spectrum user, I can pick up as many as nine of them at once. And the lot size here is about 1/2 acre. I shudder to think what it's like in an apartment/condo environment.
Jan 07, 2008 | Radio Shack Wireless Remote Extender...
Toys Logo
178 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
