Question about General Computers & Internet
I have no "Sound" setting under the general settings icon
Posted by Kenneth Bridges on
lolthepcman
    Sergeant:
  • 179 Answers
For what? is this a computer? a phone? a tv? or what?
Posted on Nov 05, 2018
Testimonial: "The question got posted incompletely. I submitted it again adding that it was about a Huawei Y3II cell phone and received a ridiculous answer about assignment writing1"
The ringing sound ... I don't know what has happened but its on silent and I can't get it off
Turn your phone off, then on again. If that doesn't fix it:
  • Check the mute/sound button on the side. It's on the left on an iPhone, and usually all androids as well. If it is on mute, there will be a red or orange stripe visible under the button. Just for grins, try turning it on and off.
  • Depending on whether or not you've accidently hit the volume controls (those buttons on either side of your phone) chances are you've set it to mute simply by the phone coming into contact with the controls while in your pocket or purse. It happens.
  • Go into your settings and select "Sounds" (on an iPhone). Make sure the ringer and alerts button is on and your sound volume is up.
  • Go to "Do Not Disturb" (under settings still) and see if your sound is turned off.
  • As a last option, select "reset" under "General."
  • Also check your settings to see if you need to update your phone. If so, plug it into a power source and select "Update" from your settings menu. You'll know if it needs an update because there will be a number on the settings menu icon.
Good luck! If you have an Android the process is similar. It's always a good idea to Google your phone model and something like "Restore sound settings" to get more specific info!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/becky_74db42375768192e
Feb 05, 2018 | Cell Phones
Tip
How to change from any Language to English Language on Nokia E71
<span>Since the phone is in another language distinct from English language, you will have to use the phone symbols as a guide to get to Language settings on your Nokia E71 and change it to English. This is because you won't be able to read or understand what's on the phone menu since its not yet in English language.<br /><br />Click menu, go to tools. Tools has a spanner symbol. Its the first icon on the second line of your phone menu. <br /><br />Click settings. Settings, also has a spanner symbol. Its also the first icon on the second line of the Tools menu.<br /><br />Click General. General is the first on the list under settings.<br /><br />Click personalization. Personalization is also the first on the list under General. It has a paint symbol/icon with red, green and blue dots.<br /><br />Scroll down by pressing the down navigation button four (4) times and you will get to language.<br /><br />Click it and the first option on the list is "Phone language". Press it and you will see a list of your phone languages, scroll to English and select it and that would be all.<br /><br />Follow the above direction and you will certainly get to English language under the phone language.<br /><br />Good luck.</span>
on Nov 19, 2010 | Nokia E71 Smartphone
How can I change ringtones on hisense u962 android
You can change your ringtone by going to:
  1. System Settings ? Audio Profiles
  2. "Pre-defined profiles": under "General," press the icon to the right: Settings.
  3. Under "Incoming Calls," choose "Voice call ringtone." Here you can set your default voice call ringtone.
Feb 04, 2018 | Android Cell Phones
Arabic
I found this posted, hope it is helpful.
Click it and the first option on the list is "Phone language". Press it and you will see a list of your phone languages, scroll to Arabic and select it and that would be all.
Follow the above direction and you will certainly get to Arabic language under the phone language.
Dec 05, 2011 | Nokia X3 Cell Phone
I want to change E63 language from English to Arabic
If you don't find Arabic amongst phone language, then it means you cannot change the language to English because it's not all language that you will find under phone language. There are limited languages there. I hope you find Arabic.
Good luck.
Nov 05, 2011 | Nokia E63 Cell Phone
To change nokia N72 from french to english
Since the phone is in another language distinct from English language, you will have to use the phone symbols as a guide to get to Language settings on your Nokia E72 and change it to English. This is because you won't be able to read or understand what's on the phone menu since its not yet in English language.
Good luck.
Nov 03, 2011 | Nokia E72 Smartphone
How do you deactivate silent mode on your phone?
You can deactivate silent mode you need to follow this simple steps first select menu then scroll to settings select this one then scroll on to the profile icon and select it there you will get number of list have silent,general,meeting,light only,discreet,beep sound,loud.Select general for canceling silent mode..All this mode contain different advantages one can have only vibrate selected and other can have low ring volume select the icon what time of sound you like.
Jun 13, 2011 | Samsung Cell Phones
Current language set in arabic. how to change to english?
Good luck.
Apr 07, 2011 | Nokia E72 Smartphone
Is there a sound/volume lock key that may have been hit by mistake........audio and sound in my computer dont see any fault, but have almost no sound
I can help you with your 'almost no sound' computer problem.
The best thing to do when you are not sure what your pc is doing with its sound is to bring up your audio mixer. Do this by right clicking on the volume control icon by the clock on your task bar and selecting 'Open Volume Control', or go through the Control Panel if your taskbar has no volume icon visible.
When looking at your mixer, set Master Volume and Wave mixer bars to about 75%. Now return to whatever application you are using and check where its volume is set. Generally, everything should be set to 75% and then your external speaker volume should be set to a comfortable level.
I hope that helps.
Aug 30, 2010 | Acer NSK8458AN Keyboard
Desktop icons. i installed win7 transformation pack and now it has large desktop icons..how to turn it into classic icons?
  1. right mouse click on the desktop
  2. select properties
  3. click the settings tab
  4. after slide the resolution to 1024 x 768.
  5. If this is too small, then change it until you are satisfied with the screen resolution.
click advanced. Under general, you'll see DPI settings if they have changed, set them back to 96. If thats not the problem, go to appearance, advanced, then icons. Set the icon size to 32, and the font to 8. If not, increase the resolution by going to settings and moving the slider.
Please don't forget to rate... :-)
Jun 19, 2010 | Microsoft Windows XP Home Edition
Computers & Internet Logo
Top General Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
roeb
Are you a General Computer and Internet Expert? Answer questions, earn points and help others
