Question about Home
Need to change time on tiny Waterford crystal clock. Battery compartment so tiny. Where is time changer?
Posted by John Murphy on
2 Related Answers
Karen Weinman
SOURCE: waterford crystal watch. how do i set the time?
There is a very tiny flap to the right of the battery compartment. You lift up on it and rotate it. As you do, the time will change. When you get the correct time, put the flap back to the down position.
Posted on Dec 12, 2011
BaronVonNuke
Mark Schmit
  • 1915 Answers
SOURCE: I changed the battery in my Waterford clock and now it is running backwards. Help!
Any chance you put the battery in backwards? If not, remove the battery, wait five minutes and then reinstall.
Posted on Jul 12, 2015
My Bose clock radio, quite old model, has suddenly started losing about 45 seconds a day so in a week it's 5 mins slow. Any suggestions and preferably fixes?
Usually when a digital clock starts losing time like that its because the crystal thats used as a time reference in the clock circuit has started to age and drift off frequency. Other then repair/replacement of components there isn't much that can be done to it. I have a couple older LCD tv's with built in clocks that display the time on the screen that do the same thing, after checking the time base crystal in the circuit its simply due to the frequency of the crystal drifting with age.
May 04, 2017 | Bose Audio Players & Recorders
Jul 12, 2015 | Home
Seiko clock battery corrosion.
Use vinegar to clean out the battery compartment. It will neutralize the battery acid. Then take what is left of the springs and pull them out so they make contact with the new batteries. Sounds like you got a hold of some bad batteries.
Feb 18, 2014 | Seiko QXM265BRH Melodies in Motion...
Waterford crystal watch. how do i set the time? i just replaced the battery and the clock is functioning but cannot figure how to set time.
Oct 15, 2011 | Guess WaterPro G12557L Watch for Women
Forgets date / time every power off/on
Yes there is and about two years is the right time for it two be losing it's power. Check on the right edge of the body and the left edge of the body, there should be a small slide out compartment for a button battery.
Sep 07, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Wrong time on Emerson Smart Set clock
This is a problem with the clocks tuning crystal. Digital clocks have a crystal that is tuned to run at a certain frequency to keep the clock working correctly. These clocks have a problem with that crystal keeping the frequency locked at the correct working frequency. This problem will sometimes cause the clocks to run fast due to a running frequency higher than the regulated frequency and sometime slow due to a running frequency running lower than the regulated frequency. The only way to fix this problem is to either adjust the crystals frequency to the correct frequency and lock it. Or change the crystal. Both these types of service require tools and test equipment to fix the problem. This is usually best handled by a service center. The Emerson customer support telephone number is 1-800-898-9020. Give them the make and model number of your clock radio and ask them for assistance. I hope this information helps you with your problem.
Nov 18, 2008 | Emerson Smartset Clock Radio
Replaced batteries= how to set clock -time, etc/
• Twist and lift open the battery compartment cover at the back of the clock and insert 1 fresh AA, LR6 1.5 volt ALKALINE battery according to the polarity marked on the case.
• Press time zone button to select a time zone.
• Replace the battery compartment cover.
THAT’S IT! During the night your clock will automatically set itself.
It will do it itself just need to wait thats all
Apr 21, 2008 | La Crosse Radio Controlled Atomic Clock
Slow clock
Is there a separate battery for the clock memory? If so I would try changing that. Otherwise the clock is probably busted. Digital clocks would not normally loose more than a few seconds a year. If the clocks crystal oscillator broke it may cause this. That could happen if the crystal was not glued down or came loose.
Jun 26, 2007 | GE 29439GE2 Corded Phone
How to change the time on the clock
You need to shut the deck off. and then set the time.
Jun 21, 2007 | Pioneer DEH-435 CD Changer
RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Mar 03, 2006 | RCA RP3721 Clock Radio
Home Logo
725 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
