Question about Vehicle Parts & Accessories
I need a operating manual for a Marquette 42-127 distributor tester.
Posted by Steve on
Why my 94 Astro van will not fire
this generation of gm vehicles is easy to troubleshoot. the engine needs 3 things to run: compression, fuel, and spark. since you mention fire, i assume you have no spark.
disconnect any random spark plug wire and connect the end to a hei spark tester. crank engine and observe for spark. if you have no spark, disconnect the center terminal of the distributor cap and use the hei tester in the same manner. spark means cap and rotor bad or bad plug wireset. no spark means make more checks.
check for battery voltage and good ground on distributor. check for open or shorted ignition module or ignition coil windings. if power and ground is present and ignition coil tests ok, check for ignition pulses at coil primary. if you have no ignition pulses feeding the coil, change the distributor.
with that generation of vehicle, the ignition system will operate without help from the computer. don't even troubleshoot the guts of the distributor, if you change the cap, rotor, and anything else, it will be the same price as a remanufactured distributor, and might not fix the problem. if you troubleshoot a low volrage related issue (no pulses, shorted or open circuit, unstable timing, etc), change the whole thing.
Jul 29, 2016 | 1994 Chevrolet Astro
Ecg service manual
Parece que usted puede comprar uno en linea. Utiliza el siguiente enlace para obtener mas informacion.
http://www.medwrench.com/?community.posts/threadNo/11208/subject/Service-manual-for-Marquette-Mac-8/
Dec 11, 2013 | GE Marquette MAC 8 EKG
2000 Chevy Astro; power to distributor from the coil, but no power out the distributor. New rotar cap, magnetic switch and distributor and ignition control module, but still won't turn over. Help!
check if fire at the end of spark plug wire with HEI spark plug tester.It need 25000 volts to jump the tester. If ok check for fuel injectors by pouring a little fuel inside intake .
Sep 19, 2013 | 2000 Chevrolet Astro
I need user manual GE marquette max-1 stress test treadmill
Hi...
i would be appreciate those who sends me MAX 1 stress test (workstation) service manual..... i tried a lot to find it but could not make it... do help me. thank you.
Apr 04, 2013 | Ge Medical Systems Ge Marquette Mac 1200...
HI I NEED GE MAC VU OPERATORS USER MANUAL KINDLY HELP
I wish to download Operations and Service Manual OF THE G.E MARQUETTE MAC VU, SOME BODY COULD HELP ME PLEASE? MY E-MAIL [email protected]
thanks
Nov 04, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
I NEED AN ECG OPERATING MANUAL
I can provide one at no charge. Send me an email if you are still in need.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com
Jul 15, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
NEED PARTS MANUAL OF GE MARQUETTE MODEL MAC 5000 RESTING ECG
I have manuals and all kinds of stuff for tech support. Let me know how I can help if you are still in need of help. [email protected] 800 989 4909. Jeff Watson
Apr 02, 2009 | Medical
Vehicle Parts & Accessories Logo
149 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
