Question about Canon PowerShot A720 IS Digital Camera
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Posted on Aug 04, 2009
SOURCE: sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Posted on Nov 20, 2011
The only time I have had this happen, is when the cicuit card inside slid back. This keep it from connecting to the PS2 memory slot. It is simple to repair, open the memory card up and slide it forward infront of the stay that supposed to keep it forward. If the stay is broken, then put someting inside the memory card to keep the circuit card pushed forward.
I did try another card and it still shows "Memory card error" It's like the spring isn't working. I can get it to stay in the slot if I wiggle the card but the error message still show up. I also tried to go in and re-format the card but the formatting menu is not highlighted and you can't get to it. Ugh of course...just when I need my camera. Any other suggestions??? Thanks!
Did you try another card?
