SOURCE: GE electric dryer disable buzzer
open the console and locate the buzer a black item in the consle look at the wiring diagram that is inside the console on a piece of green paper trace to the buzzer and remove one of the wires and tape it with black electriacal tape no more buz
SOURCE: CANT FIND MODEL OR SERIAL NUMBER ON DRYER
There should be a nameplate along the door opening. This is normally where Whirpool puts their information. Just open the door and look along the door or door frame opening. The nameplate data can also be located along the back of the operator console on some models. Let me know if you still can't find it. I hope this helps.
SOURCE: GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
SOURCE: Looking for the age of Whirlpool electric dryer
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
SOURCE: I have a whirlpool electric dryer Model No.
The cause of the problem is either a blown thermal fuse, a faulty belt switch (loose or worn out belt), a faulty door switch, or a faulty machine control board. Activate the "Diagnostic Test Mode" to determine which you should check first to avoid unnecessary disassembly of the machine.
Diagnostic Test Mode Activation Procedure
Please inform me about the result of the test to give you the exact repair/replacement procedure.
