Question about La Crosse Radio Controlled Atomic Clock
How to set clock model # 512-811 - La Crosse Radio Controlled Atomic Clock
Posted by William Pearson on
Jean DeLauche
  • 2,908 Answers
Hello, William -
If you are asking about a La Crosse Technology Atomic Clock, then . . . see the instructions (24 page PDF document, Adobe Acrobat Reader software - free - needed) here:
https://www.lacrossetechnology.com/media/catalog/product/5/1/512-811-bbb.pdf
Best wishes.
Posted on Nov 04, 2018
Have a Whirlpool over-stove microwave. Can set time but then it scrolls between AM & PM. Cannot find how to set the AM/PM portion, and completing the time set.
Which microwave model do you have? Most of the Whirlpool microwaves that I know only have a 12-hour clock. They do not indicate AM or PM. To set the ones that I know, press Clock. Type in the current time in a 12-hour format. Press Clock again. The only model that I find quickly that has an AM/PM option is the GH7208XR. On that model, start with the main menu displayed on the LCD screen. Touch Settings and Info. Next press Clock. Then press Adjust Time. Follow the instructions to set the time and the AM/PM setting. I'll assume you use the +/- buttons. To hide the clock, get to the Clock Screen. Press Adjust Time and Hide Clock to return to the main menu. See these two pages of the manual for this model: https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=9#manual and https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=12#manual
Current Whirlpool over-the-range models sold in the US are listed here: https://www.whirlpool.com/kitchen/cooking/microwaves/over-the-range.html . Other Whirlpool appliance manuals are available from the Owner Support page: https://www.whirlpool.com/services/manuals.html.
I hope this helps. Please add a comment with the model number for a more accurate information on setting the clock. The model number should be inside the microwave on the rim. Usually it's on the bottom of the door frame near the door hinge.
Sep 19, 2018 | Whirlpool Microwave Ovens
W & H clock how to set winding mechanism
Hello, Swannie -
Are you asking about a Winterhalder & Hofmeier clock? If so, what model are you asking about? You can add the model information by choosing Comment and typing the information.
If you do not know the model of the clock, if it is not a tall case (grandfather) clock and you can transport it easily, I suggest you take your clock to a reputable clock repair shop in your area and ask one of the knowledgeable people at the shop about setting the time and winding your clock.
Best wishes.
Apr 02, 2018 | Watches
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
How do I set the clock
On some Galanz models setting the clock is a bit unusual.
You have to press the clock/preset button once then press pause/clear. Now it is in Clock mode setting and you can set the hour then press clock/preset again to set the minutes then press once more clock/prest to finish the operation.
Mar 27, 2013 | Microwave Ovens
How to set time on model 13003
Hello
Get into this link. You can get all the details for your clock radio from there.
lib.store.yahoo.net/lib/partshelf/Acu-Rite-00592W-Manual.
Nov 17, 2011 | Acu-Rite Adagio Clock Radio
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
I have a lacrosse technology wall clock how do i set the time
You don't set the time. You set the Time Zone and it sets itself.
What model is YOUR clock?
This site lists several models of La Crosse wall clocks with downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
The link below is generic but there are specifc downloads for clocks with other features.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
Setting clock
It depends on the brand and model.
Normally it's a sequence like:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
If not, please post a new inquiry with your correct brand and model.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 23, 2010 | Magic Chef MCD1311ST Microwave Oven
Tivoli model three clock problems
SELL! SELL! SELL! Yup the clock has bit the dust sell er and cut your losses.
May 12, 2009 | Tivoli Model Three Clock Radio
La Crosse Radio Controlled Atomic Clock Logo
253 people viewed this question
Top La Crosse Home Experts
Are you a La Crosse Home Expert? Answer questions, earn points and help others
