Question about JVC Car Audio & Video
You can get parts here. Look at the ribbon cables running from the T-Con board down to the connectors on the screen. The board itself is probably causing it but check the cables first. You can get parts online from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Nov 03, 2018
SOURCE: Video out problem
I own a DMR-ES20 and had that problem. Panasonic Customer Service gave me a fix that works.
On the unit itself, press STOP and PLAY at the same time for about 10 seconds. This fixed my player.
Posted on Jan 07, 2008
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
SOURCE: Color code for 4-pin Cobra M75 CB Mic
here is the link that i used
hope it helps
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=8197
Posted on Jul 03, 2009
Feb 21, 2017 | JVC Car Audio & Video
Feb 16, 2017 | Chevrolet Express Cars & Trucks
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Nov 03, 2012 | Cars & Trucks
Jun 06, 2011 | Televison & Video
Dec 25, 2010 | JVC Car Audio & Video
Oct 30, 2017 | JVC 47 in. LCD TV
Sep 08, 2009 | JVC KD-G210 CD Player
Aug 13, 2009 | Car Audio & Video
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
64 people viewed this question
