Cameras Logo
Question about Cameras
What to do when rechargeable battery gets wet
Posted by Lorraine Macdonald on
Daniel Youngman
    Habit-Forming:
    New Friend:
  • 68 Answers
Be very careful using a lithium battery that's been submerged
Posted on Nov 10, 2018
Jack Guyton
    New Friend:
    Problem Solver:
  • 13 Answers
Buy a new one!
Piyush Lal
    Novelist:
  • 149 Answers
Wipe the battery from a dry cloth or a tissue and then keep the batteries in an uncooked rice bowl. Rice tends to absorb the moisture off the battery.
Keep it for around a day or two. Do not charge the battery nor use any Hair Dryer to dry the battery.
Hope this helps
Posted on Nov 03, 2018
Toshiba laptop p855 battery wear started increasing
Yep, BATTERIES begin to die... from the moment they are made... even while they are "new" sitting on a shelf somewhere... it's called "shelf life". Maybe the exception is a 'wet' battery where the ACID is added at the last moment before use?
Also MANY/MOST rechargeable batteries can be seriously DAMAGED with a TOTAL discharge... In most cases batteries HATE that event and will punish you with "memories"!
Even ONE incident MAY severely cripple your recharge abilities and this is especially true with cheaper batteries with poor chemistry inside. Understand this is NOT to say more expensive batteries are bullet proof.
A few rechargeable batteries LIKE to be thoroughly "exercised" and a "deep cycle" car or RV battery is the best example of that, but even a deep cycle has it's discharge limits!
SO... when you get your first "LOW BATTERY" alert take it VERY seriously... end your session as soon as possible and bring your Frankenstein back to life again and again.
See this link for GREAT battery insight and assure a long life. Trust me, this topic is not fiction or fable.
Anthony
https://en.wikipedia.org/wiki/Memory_effect
1helpful
2answers
I have a scunci rechargeable wet and dry vac. Model 52069. I plugged it in to charge green light turns on. Couple hours later I unplug it and push the button nothing. Need instructions or manual.
Most likely the rechargeable battery needs to be replaced.
Unfortunately, I haven't been able to find a battery pack listed anywhere. You'll probably have to have a company like Batteries + Bulbs (In the USA) take it apart and replace the battery pack.
1helpful
How do I access the battery? And how do I recharge the battery?
Battery is Usually located under the seat of Most Motorcycles. Remove Battery and Get a 2amp trickle charger for both Wet and Gel Cell batteries Fallow Normal Charging inst.
Sep 23, 2015 • Motorcycles
We have a scunci recharge cordless wet-dry vac model # 52033. The battery does not charge. What can we do to fix this?
if the charger is working, and the battery does not hold a charge for very long, you will need a replacement battery. this is the most likely problem. if the battery does not charge at all it may well be the charger and you will need to replace that. hope this helps
Got wet. Won't turn on
125 degrees is too hot! A camera should be dried buried in a bowl of dry rice for a week, not in a hot oven.
Sony t90 got wet with a water splash during swimming now i cant take pics and there's "E:62:02" Constantly flashing.can u pls help me?
Open the battery compartment and remove the batterys and the memory card. Completly dry the camera as best you can without further damaging it. Let it set open up like this for about 5 to 7 days. Recharge the battery and reinsert the battery and memory card. If you have to reinsert the battery to recharge the battery, do so. If it still doesn't work, contact the factory for a repair estimate.
1helpful
Oreck Electrikbroom (battery) won't hold charge and pick up dirt.
Battery needs to be replaced. All rechargeable batteries have limited recharge cycles. NiCad's are usually used in these and also develop "memory' which keeps them from recharging fully.
Contact Oreck or reputable dealer for replacement.
5helpful
Rechargeable battery
Hi, try looking on ebay, user name; itl-e. His shop name is; Component-shop. A wide range of batteries supplied including a 6V 5AH which sells for about £8 including p&p. Your Panasonic battery is rated at 6V 4.2AH, so the replacement will last slightly longer between charges. If you want an exact (Panasonic) replacement, try putting "Panasonic LC-R064R2CH into google.
Hpoe this helps! Bob.
Wet Dell XPS M1210
I would try cleaning the terminals on the battery and the computer with an old toothbrush and simple green or other multi-purpose cleaner, that doesn't leave residue.
Top Cameras Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
