Look at the circuit breaker that powers the plug that the oven is plugged into. It should be located near the power meter on the house. It will be 2 breakers with a metal pin connecting the trip levers. Usually, one breaker trips and the pin is supposed to trip the other. This doesn't always work as advertised so only 110 volts is available to the oven. The heat elements need 220 volts to work. Try manually resetting the breaker first. If that doesn't work, then replace the breaker.
SOURCE: ZBF360X Electric Single Oven: fan oven working but no heat...
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
