Cameras Logo
Question about Nikon Cameras
Nikon Coolpix B500 - Can I keep the flash on during Video recording.
Posted by Michael Troso on
Tony Parsons
  • Nikon Master
  • 6,402 Answers
Think about it - flash, as the name suggests, emits a single bright burst of light. Video recording requires constant lighting. All you are likely to get is a single vastly over-exposed frame every ten to twelve seconds on an otherwise unused recording medium.
Posted on Nov 03, 2018
5 Related Answers
Anonymous
  • 744 Answers
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jun 28, 2009
Anonymous
SOURCE: flash doesn't work on nikon coolpix l12
I actually just fooled around with mine because it was doing the same thing. It will only flash in the scene mode, but not the normal quickshot mode. i noticed under the camera symbol on the screen said BSS and i went into the menu and clicked on BSS and turned it off b/c it was on and that worked finally.maybe u can try it, if its the same situation.
Posted on Aug 07, 2009
syed mahmood
  • 77 Answers
SOURCE: my nikon coolpix s230 wont let me use the flash
u have to change the battery by using 2100 mh ur broblem will resolved
Posted on Nov 01, 2009
Anonymous
  • 32 Answers
SOURCE: wont pause
For the Nikon Coolpix series, I don't think it's possible.
Posted on Jan 24, 2010
Anonymous
SOURCE: Sound problems with my Nikon Coolpix 4600 camera
Coolpix 4600 has no microphone, 5600 has one.
Posted on Mar 07, 2010
1helpful
Why does my Nikon Coolpix L820 when during making a video it will sometimes Muffle my voice during a short video or long video?
The manual says that the stereo microphones are either side at the rear of the flash. Make sure nothing is near them. It also says that it can be affected if the flash is raised. It sounds like a firmware issue, and it is a pity there is no external mic jack socket.
https://www.google.com/search?q=nikon+coolpix+l820+video+muffled+audio
Dec 30, 2022 • Cameras
Nikon B500 camera. I put a new memory card in my Nikon B500 and the camera says 'card not present'.
Is it this type of card?
The B500 is compatible with SDHC and SDXC cards. That means you can use cards from 4GB all the way to the largest cards currently available. (at that time 128GB)
And is it less than 128GB?
Your Nikon Coolpix B500 Digital Camera is compatible with 16GB, 32GB, 64GB and 128GB SD, SDHC and SDXC memory cards.
https://www.google.com/search?q=nikon+coolpix+b500+compatible+memory+card
How do you reset a Nikon Coolpix B500 to default settings?
Starts here
2:02
22 second suggested clip
Screen. If so what you're going to do is again just scroll. Down all the way to the bottom here andMore
How to Factory Reset Nikon Coolpix Camera - YouTube
YouTube · Tech Talk
About featured snippets
Feedback
People also ask
How do I reset my Nikon Coolpix to factory settings?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I reset my Nikon Coolpix camera?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I reset my Nikon Coolpix p500?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I reset my Nikon D5000 to factory settings?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Feedback Web results
Reset All - Nikon Coolpix B500 Reference Manual [Page 160]
https://www.manualslib.com > ... > Reference manual
Nikon Coolpix B500 Manual Online: location data, Reset All. Press The D Button M Z Menu Icon M Location Data M K Button Set Whether Or Not To Add Shooting ...
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
How do i record video with nikon coolpix b 500
The best solution would probably be to go through the manual of your camera to see what all of the buttons do, because I have a feeling that you still didn't figure out the basics of your device :) If you don't have a manual you can find it here:
Nikon Coolpix B500 PDF manual download
Wont pause
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
