Question about Boss Car Audio & Video
I have BV 9965 BOSS my video is not displaying rest all functions r working what could be the probable cause.
Posted by SHASTRY Bommakanti on
2 Related Answers
Siddique M A
  • 442 Answers
SOURCE: The display of my boss bv 9974 is too dark!!
If the display is too dark from the start, that is from the point you get the compaq logo then the issue should be with the LCD panel. if it is dark only in windows you can try increasing the brightness by using the Fn Key and the brightness up option in the keypad.
Posted on Feb 08, 2012
Dana Taylor
  • 163 Answers
SOURCE: Boss 9965 motorize 7' screen motor not working
Posted on Apr 24, 2017
How do I do a factory reset on my boss bv 9962
Contact Roland Customer Service to get the correct information.
Apr 28, 2015 • Boss Music
1helpful
Does anyone know what to do with white wire on the back of boss audio system 7948B? it says camera 12v
IF you are not using the dedicated power connection for the camera, just tape it off and tuck it out of the way. As for the camera not working, have you confirmed that it is getting power through the backup light tap?
Bv 9962
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
2helpful
I damaged my boss BE 50 by using the wrong polarity. now it only works on batteries. what can I do.
You are probably fortunate that more damage was not done.
Open the unit and you will likely find a protective diode at the input and either a fuse or that a circuit trace has been blown. Replace whatever is not conducting the power from the power jack to the rest of the circuitry. The diode is probably OK as usually the battery power is across it when the battery is used.
Aug 10, 2010 • Boss Rc 50
Which brake to hook up to
emergency brake wire in the vehicle
26helpful
8answers
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
Car Audio & Video Logo
Top Boss Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Morne Olivier
Morne Olivier
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
