Question about Vehicle Parts & Accessories
I have a Clifford 5706v blue light flashing when armed meaning
Posted by Mark on
Need install manual for a viper 4606 v
Same as the 5706v. Here is a current link for the quick install guide.
http://www.net-import.dk/images/viper%205606v%20installationsmanual.pdf
Also 5706v install guide available at "the12volt.com in the downloads section need to be registered to download.
Sep 25, 2014 | Remote Start System
Constant flashing blue light
The flashing blue light means the Bluetooth is connectedconnected, device is on.
Jan 31, 2014 | Hmdx Hx-p240gy Jam Plus Portable Speaker,...
Lost key to alarm
You will need to contact Clifford and provide the alarm unit serial number and some other details, they should then be able to send you a new key. Failing that, call a car recovery service (AAA, RAC ADAC or AA) they can usually help.
Jul 21, 2013 | Clifford 507X Security alarm + Remote...
I just had the viper 5901 installed and was wondering if I could have that blue flashing light disable as I feel it is too bright and draws attention to the vehicle. Can that be done?
The flashing blue light is to tell potential thieves that the vehicle is armed with a security system, making a potential thief less likely to break into it.
Apr 27, 2011 | Viper 620v Blue Flashing Light 5901 5701...
Clifford alarm 7000 how to fix troubleshoot
snap , they are **** , cant even start my nissan , it just keeps locking and unlocking the car ....and nothing ggrrrrrrr
Dec 13, 2009 | Vehicle Parts & Accessories
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
The indicator light (blue) on the sensor that attaches to the windshield is flashing repeatedly. My remote is also not working.
Hi ,sounds like a Clifford well known for problems would suggest calling an alarm specialist for you alarm,but usually cheaper just to have a new alarm fitted.
Aug 06, 2009 | Vehicle Parts & Accessories
Clifford wont cherp
refer to the owners manual your LCD screen should have a menu/setting/etc. type of thing to help set back the chirp..
Jun 24, 2008 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
233 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
