There are many possibilities to this fault. Just contact any service technician in this case. It will be much better. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
there is a fuse on the power section of the board. remove the back case and follow the plug. it'll lead you there. check the fuse with a multimeter. if it's bad, replace it with the exact type. if it's ok, you have a power issue. check the caps for puffiness. you may need to have it looked at.
This is the closed captioning, even though it may not contain writing in the block. If you can access the main menu then you can try and turn the CC to off. Otherwise you are stuck with it.
