Question about Westinghouse Refrigerators
Our westinghouse side by side ice fridge is saying L1 or LI?
Posted by Andra Cawthorne on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
You can look up Electrolux codes on google.
Posted on Nov 03, 2018
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Posted on Mar 10, 2008
danny Hendrickson
  • 2468 Answers
SOURCE: My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Posted on Jan 17, 2010
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: Westinghouse WSE6100SA fridge in side by side fridge freezer free
the thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Posted on Feb 19, 2010
Testimonial: "Thanks for you fast response, very helpful. I thought this may be the problem but wasnt sure. Are the thermostats easy to replace? Could I DIY, How?"
Anonymous
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
Ryan Pries
  • 257 Answers
SOURCE: i have a side by
Insert a pin in the slot under the lower edge of the trim, You should see 2 small holes, that will release the lock tabs, from there you can just pull the frame toward you, Inside you will be able to see the problem.
Posted on May 19, 2011
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Westinghouse frost free freezer
You don't say from what part and what it sounds like.
If it's a cracking noise, I had the problem in a similar fridge - the repair person said the noise was most likely the sound of ice build up being removed during defrost cycle and not to worry. Suggest you check the freezer temperature is not too cold and building up excess ice.
Mar 02, 2013 | Westinghouse Refrigerators
I have a side by side westinghouse fridge with water and ice dispencer. the springs that control the lever for ice dispencing are either of their hinges or fell off how do i get in there to fix it
May 19, 2011 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Jan 31, 2010 | Refrigerators
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Water dispenser
Mar 08, 2008 | Refrigerators
Refrigerators Logo
136 people viewed this question
Top Westinghouse Refrigerators Experts
Vincent G
Vincent G
Sheldon Dedek
john h
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
