Question about Boss Car Audio & Video
Need help boss audio bv765b touch screen not working consistently
Posted by David Lane on
I have a boss audio touch screen receiver and I just purchased a pioneer deh-p3000. I was wondering if I can also install the pioneer and use the pioneer for music and still use the boss for videos?
yes you can do it only you have set other wirring for this beacause it aalso take more power and the wire are not instal for this purpose so you have to take othe wirring kit and instal this and you can you enjoy
How to reset screen
Not sure which model you have, but on most Boss models there is a little button on the front of the unit that you need to push with a pen. The button may say RES next to it. It also may be in the back of the unit.
Somewhere on the unit there is a button! Push it!
Find your manual using the link below if you can't find the button.
Boss Car Audio Manuals
My boss BV9976 dvd player touch screen is not working
It's possible that the Boss unit works with iPod and iPhone 3 and not the four. Does the unit state that it works with iPod/iPhone? Also, you may require a software upgrade
I just get a pedalboard. I have some bosspedals. What about their polarity ?
Be careful, while most pedals are consistent with the 9 volt DC polarity, SOME BOSS pedals use AC inout. Those typically will appear to work on the DC inout, but fail to pass audio through the effect. Read instructions for EACH pedal and verify the requirements.
I have a 9560 and when I plug my ipod touch into the usb port the system will go to the usb screen and the load bar at the bottom will progress about halfway before it just stops and goes back to the radio...
First i recommend you to check with the manufacturer or dealer, the compatibility with your iOS version, second, try backing up your iPod and re-loading some songs, if it works, then the problem is with some song's information...
1helpful
4answers
Boss bv9995b touchscreen not working
You need to calibrate put a DVD in on the remote press stop,zoom, up, down screen should pop up touch the cross touch the cross at each corner u will see ok turn off and back on and try it
Ive got a delay ,chorus , wah ,distotion and compressor . how would i aet them in which order . thanks
Generally speaking, other than having hte compressor first to provide a consistant level to the other pedals, the order is personal preference. You need to experiment and determine the types of sounds you want. There is no "standard" order.
Dan
Car Audio & Video Logo
Top Boss Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Morne Olivier
Morne Olivier
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
