Question about Jenn-Air Refrigerators
Jenn-air side by side refrigerator the ice maker works but the water dispensor doesn't. You can hear a hum in the door when the lever is pressed.
Posted by mike moore on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Possible faulty water solenoid valve may be the problem not letting water through.
Posted on Nov 03, 2018
  • mike moore
    mike moore Nov 05, 2018
    where is the water solenoid located?
5 Related Answers
Anonymous
SOURCE: Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Posted on Jan 03, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
Anonymous
SOURCE: jenn air side by side refrigerator ice maker not working
On mine the water inlet feed tube would freeze solid. Removing the ice tray and using a hair dryer to completely thaw the tube would get it working for another month or so. My frig had a solid rubber inlet tube. I noticed at the appliance store that newer models had an inlet tube that was split on top. I got one of these from a local appliance parts store, and it fixed the problem. The tube replacement it easy. Get to the back of the frig. Turn off the water supply. Carefully pry the white plastic piece out ( located on the upper right side when facing the back of the frig. ) of the frig. When you have the new one in hand it will be clear what you are going to do. Pull out the old remove the water line. Attach the line to the new tube and insert it. Turn on water, check for leaks, and you should be ok. This repair is only effective if you have an inlet tube that freezes up. There can be many other malfunctions that stop ice makers from working. This was my problem. Replaced the tube 3 years ago and ice maker has worked fine since the replacement.
Posted on Nov 24, 2008
itls
Vic Stellway
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
Anonymous
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
[email protected]
Posted on Feb 13, 2010
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
No Water from Door
Same problem with mine, no water, but could hear humming when pushing dispense lever. There is a coupler in the water line below the freezer door, I pulled it and opened it*, water came out when actuating the dispense lever. So it wasn't frozen between there and the wall, had to be frozen inside the freezer door. Solution? Turn off freezer side of the fridge and leave door open for an hour or two, voila, water in door again. *little blue coupler, push white collar in towards blue plastic to release line, push line back in all the way to replace it. This line has pressure only when dispensing water, and then not much pressure.
Dec 19, 2009 | Hotpoint HSS25GFP Side by Side...
Ice Bin Dispensor freezes
you might try asking the mfg. site about this problem
https://jennair.com/appliances/details/JS42SSDUDE
did a search and nothing else come up. give them a try.
Dec 02, 2017 | Jenn-Air JSD2690HES Stainless Steel Side...
Water dispensor on freezer door does not work
usually you could have a bad water valve. the dispenser side of the valvle could be froze up. if not then there is a small micro switch above the dispenser lever.
Jun 21, 2009 | Refrigerators
ice maker?
[email protected]
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker does not despence ice
thanks for the question if it only clicks & a hum its jammed if a click but no humm it could be the motor remove the motor and give it 110 volts on the bench this will tell you thanks the appliance doc
May 13, 2008 | Jenn-Air JCD2389G Side by Side...
Open Questions:
Refrigerators Logo
113 people viewed this question
Top Jenn-Air Refrigerators Experts
john h
Sheldon Dedek
Marvin
Marvin
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
