Question about Bose Audio Players & Recorders
Nissan Sentra Sl 2018
SOURCE: Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Posted on Mar 19, 2007
SOURCE: bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Posted on Dec 18, 2007
SOURCE: bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Posted on Jan 18, 2008
SOURCE: Bose 901 VI speakers used with sub woofer and Bose mo. 141 rear speakers
just connect 2 speakers to each output.
Posted on May 18, 2008
SOURCE: Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Posted on Sep 17, 2008
Jun 11, 2017 | 1999 Chevrolet Blazer
Aug 21, 2011 | Car Audio & Video
Feb 25, 2011 | Pioneer Audio Players & Recorders
Jan 30, 2011 | Nissan Titan Cars & Trucks
Aug 14, 2010 | 2007 Nissan Sentra 2.0 SL Sedan
Dec 05, 2009 | Audio Players & Recorders
Jul 01, 2009 | 2002 Nissan Sentra
Mar 25, 2009 | 1995 Nissan Sentra
Mar 18, 2009 | Bose 901 VI Main / Stereo Speaker
Dec 01, 2008 | 2007 Nissan Sentra 2.0 SL Sedan
ENCONTRASTE EL DIAGRAMA?
