Bizhub c360 fuser - Office Equipment & Supplies
1 Related Answer
peter shockey
SOURCE: c3421 bizhub c360
fusing unit problem not heating up.generally replace.
Posted on Jul 11, 2013
C-F907 bizhub C360 -
sir, MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 22, 2016 | Konica Minolta Bizhub C360
How can i fix error message c-3721 on bizhub c360 machine
If this code come back after this procedure get a new fuser, do NOT reset and Reset dealing with the fuser it can catch on fire that will ruin a perfectly good day
1.
Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
May 07, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c360 cannot stabilize color
what code is showing what do images look like????
Apr 17, 2014 | Konica Minolta Bizhub C360
Bizhub c360 error code 12
l-12 or p-12 code????????????????????????????
Feb 07, 2014 | Konica Minolta Bizhub C360
Bizhub c360 prints with a pink background when printing from the computer
replace the magenta image unit drum and developer units
Feb 02, 2014 | Konica Minolta Bizhub C360...
What is error 550
replace the fuser, if not then check control board
Dec 27, 2013 | Konica Minolta Bizhub C360
Where is ozone filter located on bizhub c360
left side rear, mid
Nov 20, 2013 | Konica Minolta Bizhub C360
Fuser on C220 Konica Minolta
Use the setting thick 3 its the catch all for weird issues. make sure the paper is not coated also. if that still does not work you can go into service mode and bump up the fuser temp , its the number 1 button(machine).
Jan 08, 2013 | Genuine Konica Minolta Konica Minolta...
An error on my c360 konica minolta c-3721
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
Dec 11, 2012 | Konica Minolta Bizhub c203 Copier
Our office's Konica Minolta Bizhub C360 is always
This model has a tendency to fold corners. Have the tech. check the input guide to the fuser unit and also to check the door on the right hand side above the bypass tray. Its a fairly common issue. Also have them search konica-minolta's website for other techs having this problem. Good Luck !
Aug 11, 2011 | Konica Minolta Office Equipment & Supplies
35 people viewed this question
Marvin
Marvin
